Sub box building program...
Username: Bassheadjosh
Utica, MI US
Post Number: 85
I'm looking to build two boxes for a pro audio setup, 4 18" subs each. I'm trying to duplicate a design by a company called Electro-Voice. They used to make this box that was a 4th order bandpass with 4 18" subs...one of the best sounding, most efficient, cleanest boxes I've ever heard. The box looked fairly simpple, more or less a cube with the subs facing one left, one right, one up, one down, 4 ports one at each corner...well I want to build that same box but with some better subs, and I want to build it to the specs for those subs...so any ideas?
Utica, MI US
Post Number: 87
Oh yeah, I forgot to say that the inside of the box was open, meaning you could see the baskets of the sube...thanks for the help guys!
Username: Johammbass
IRL
Post Number: 582
You are welcome:-)
Username: Phil_salisbury
Post Number: 118
If you want to duplicate an enclosure similar you what you have seen and heard in the past, you might want to try contacting the company.
I doubt though the company would be willing to just hand over the enclosure design, especially if the company in question produces the enclosure's.
