Just got some subs
Username: Atomiclee
Post Number: 36
I blew a sub so I went and got 2 more. I got 2 Xtant 1244 in a ported box for $150. I am goin to run the with the BX1500d, 1500 watts at 1 ohm. Is that too much for these?
Also, what size speaker wire should I have wiring these together and 2 the amp? Does it matter?
Username: Ctmike
Ct.
Post Number: 2257
what's the rms of those subs cause that amp is overrated and you wont see 1500wrms.
Username: Atomiclee
Post Number: 37
I belive its 500 watts. I just need to know about the speaker wire size so I can put them in. Its the only thing holding me up!
Username: Atomiclee
Post Number: 38
Can anyone help out?
Username: Alias747
Eclipse Ti, MN
Post Number: 1530
Yeah those subs are 500 wrms. That amp is going to be a little overrated, so you should be just fine. As for the speaker wire I would go with some 12 gauge, even 14 gauge will be fine. I run my sub on 10 gauge but that is just me and it is probably just overkill. Those are nice subs btw. :-)
Username: Rvlacos
DD 3512 United States
Post Number: 342
i use 8 gauge for my speaker wire!
Username: Atomiclee
Post Number: 39
So I get it all in a get it all wired and......nothing! The amp turns on but the subs arent getting any signal. What the hell?
