........... HelP Me Out..........
Username: Mike20
Post Number: 20
Im still Fu**in wit this alpine stuff and i need to know if anyone know the RIGHT way to wire my Alpine x-10.. Its a dual 4ohm voice coil. So how many ohms can i hook it up as and how, to my alpine mrd1005 monoblock.. I used this guide and did it as the 2 ohms load diagram. Is that Right?http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =1&impedance=DVC4x2
Username: James1115
Ct
Post Number: 7327
yup
Username: Mike20
Post Number: 21
I tried it like that and its still making a weird noise when its on and hardly even hitting... I tried doin wut sumone said about a AA battery and touchin it on the positive and negative with wire and if u hear the little pop on the sub your voice coils are not blown.. So that means the subs not screwed up rite.. I just dont know wut the hell to do anymore..
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 9829
that sub only comes in DVC 4ohms right??
Username: Mike20
Post Number: 22
on the magnet it says Dvc 4ohms+4ohms
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 1232
Did you wire + to + and - to -?
