Silver Member Username: 420alldaylong
Post Number: 678 Registered: Sep-06
Posted on RE,Fi,DD,AudioQue How are there lower priced subs? Are they any good or no? |
Gold Member Username: Drsmith
Montana
Post Number: 1613 Registered: Nov-04
Posted on yes they are good, each of those brands is very nice and has excellent build quality |
Gold Member Username: Southernrebel
Monroe,
Louisiana
DD 9515d~~]...
Post Number: 3698 Registered: Mar-04
Posted on they dont spend any $ advertising. less $ spent by company = lower price to consumer |
Gold Member Username: Basshead86
Try Google
Post Number: 8172 Registered: Aug-05
Posted on they rely on WOM. |
Post Number: 679 Registered: Sep-06
Posted on Does any body have the lower priced RE,Fi,DD,AudioQue? If so which ones do you have and what amp are you useing. |
Post Number: 681 Registered: Sep-06
Posted on Does anybody have the lower priced RE,Fi,DD,AudioQue? If so which ones do you have and what amp are you useing. And what size subs are they? |
Silver Member Username: Sb2012
Iowa
US
Post Number: 430 Registered: Jul-06
Posted on well im not real sure what ur askin... but i have 1 12" AudioQue HD3 on a HifonicsBXi1606D
Post Number: 682 Registered: Sep-06
Posted on Shawn I'm talking about the entry level subs from RE,Fi,DD,AudioQue. And how does that HD3 12" sound on that BXi 1606D and what kind of box is it in. What DB are you hitting. |
Silver Member Username: Dmm2005
Digital Designs,
Raleigh BWO ...
Post Number: 116 Registered: Aug-06
Posted on i will have four 1012s on a HCCA-D5000 very soon and when i do i will let you know |
Iowa
US
Post Number: 431 Registered: Jul-06
Posted on ooooooooooooooooooooooooooooo entry level...haha whoops but anyways...its really loud and has pretty good SQ 2.5 cubic feet tuned 36 Hz |
Silver Member Username: Night_mirage
Amman,
Jordan
DDs dealer i...
Post Number: 581 Registered: Jan-06
Posted on 512 from DD RE from RE but i do n't know about AQ and Fi .. U can get DD 512 or 1000 series |
