Cutting on and off???
Username: Splmonster
Nowhere, OH USA
Post Number: 523
well, i was just driving the other day and the sub just cut off, so i quickly turned it off, then about 5 mins later i turned it back on it hit for a bout 10 seconds and cut off again. i kinda checked most of the connections, but just a quick what are some connections that i should check?
Username: James1115
Ct
Post Number: 7219
check the pressure in your right front tire it should be around 36 psi, if not I bet thats your problem.
Username: Boomtank
Post Number: 91
lol front tire hahahah. Is ur amp hot, my ald amp did that when i ran a 1 ohm load and it was 2 ohm stable
Username: Mike20
Post Number: 13
check all your connections, it could be alotta things...
Nowhere, OH USA
Post Number: 525
dammit, james thats what it was thanks man
Username: Basshead86
Try Google
Post Number: 8214
James is a smart mudafuka....
