Blown???
Username: Thumping_corsica
Saginaw, miUnitd states
Post Number: 110
Hi, well I have 2 pioneer 4 by 6's in front of car and i do play them pretty loud sometimes. but anyways the one on the passenger side is noticeablly a ton louder than my side and i dont understand or know what happened.. it didnt use to be like this they use to be even.. just the past couple weeks.. well tell me what you think it could be please. thx
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 691
sounds blown, but i'd take off your door and check em out to see if something easily noticeable happened to them
Username: Theweasel
Post Number: 692
also, it could be the amp that has something wrong with one of the channels. what amp are you running them on?
Post Number: 113
im not using an amp for them... just my hu which is an explode cdx-f5710
Username: Johammbass
IRL
Post Number: 462
Check your Right to Left fader?
