Bronze Member Username: Sk8erjim
Scottsmoor,
Florida
U.S.
Post Number: 80 Registered: Jun-06
Posted on is it going to make a big difference if the box specifications for a 15 inch soundstream sub are 4.25 cu ft and i get a box that is 5.63 cu ft? |
Gold Member Username: James1115
Ct
Post Number: 7156 Registered: Dec-04
Posted on are they tuned to the same frequency? I am assuming it is ported not sealed. Yes that will make a big difference. |
Gold Member Username: Basshead86
Try Google
Post Number: 7891 Registered: Aug-05
Posted on you decrease power handling of the sub by putting it in a larger box.. |
