OT: Interior Neon
Username: Crayola0
Wisconsin
Post Number: 1312
How do u hook it up? Could u wire it up to a switch and then run it to the yellow constant 12v wire for ur HU?
Username: Stnorris
Not yet decided, IA US
Post Number: 1500
just use a switch, and hook the power wire into a fuse (not car lighter) so that it turns on and off with the car.
Username: Stnorris
Post Number: 1501
1500 looks good ^^...damn.
Username: Crayola0
Wisconsin
Post Number: 1313
but i wouldnt want it on all the time just at night. But would my idea work? or would it be better to wire it to the red wire?
Username: Logan__tille
AudioqueUSA
Post Number: 2046
i would just run it through a switch
Username: Crayola0
Wisconsin
Post Number: 1315
thats what i was gunna do and then hook it up to the yellow power wire that the hu hooks up to
Username: Adddisorder
West palm, Florida
Post Number: 1503
hook the + wire up to a fuse in your fuse box inside the car. like the one for your radio. then put a switch on that line and ground it to the chasis somewehre
Username: Crayola0
Wisconsin
Post Number: 1316
aight thanx
Username: Riskyb
Post Number: 317
I am also interested in this. How do you run it to a fuse? Twist it around the little blade thing on the fuse lol?
West palm, Florida
Post Number: 1529
yeah thats exactly how you do it. and then just put a switch in the + line so you can turn it on and off. the only thing is it wont be able to be on when the car is off
