Help with box for dd
Username: Rvlacos
El Paso, T.X. United States
Post Number: 219
i am tryin to figure out the specs (volume and tunning)for this box i keep gettin asked and i dont know please help. the box is 12" deep.. 40" long..16" high/tall.. the port is 4" wide.. 14.5"' high'tall, then the port goes 11" deep bends right and goes 17" more right. i tried drawing it in paint but it wouldnt load. box is made of 3/4 mdf.
Username: Rvlacos
Post Number: 220
bump
Username: Rvlacos
Post Number: 221
i want to try and find out after port and sub diplacement sub is dd 3512 and made out of 3/4 mdf
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1400
Total: 4.444cu.ft
Vb: 3.019cu.ft (before sub displacement)
Fb: 39.24hz (before sub displacement)
I would have done 2.5cu.ft tuned to 35hz myself but 40hz is what DD recommends, box size is too big IMO.
Username: Basshead86
Try Google
Post Number: 7799
Box is 2.45 cubes before sub displacement. so prob like 2.2-3 cubes after sub. :-)
tuned to ~40hz
here is as close to your box as i can get it:-):-)
http://www.subwoofertools.com/forum/ported-box.asp?Ew=40&Eh=16&Dia=6&Xmax=26&Vd= .16&NumW=1&Vb=2.29&Fb=41&Qts=&Vas=&Fs=&CE=0
Username: Rvlacos
Post Number: 223
any1?
Username: Frkkevin
Post Number: 1401
****EDIT****
Sorry, I messed up. Always forget to make sure its external dimensions..
For the dimensions you gave being external..
Total: 3.392cu.ft
Vb: 2.004cu.ft (before sub displacement)
Fb: 48.67hz (before sub displacement)
Tuning frequency is too high.. would be good for SPL but not much of anything else.
Username: Rvlacos
Post Number: 226
muddy why are you and kevin's so different?
Username: Frkkevin
Post Number: 1402
No clue... first one I posted was for the dimenions you gave but being internal measurements. For external measurements the second one is accurate. I used Bass Box Pro 6..
Try Google
Post Number: 7801
b/c i took into account the box's volume AFTER port displacement. :-)
the port isn't airspace for the sub, it is simply a port. the sub is seeing ~2.29 cubes of airspace, and b/c the port is huge, it takes up the rest of that 3.39 cubes. :-)
the port has .93 cubes of airspace alone:-)
Try Google
Post Number: 7802
i figured up the box's internal volume, and then the port's internal volume, subtracted it from internal, and that is what the sub is getting. then i fugged with the Xmax and tuning until i got 58sq.in. of Port area and a 4" wide port and ~28in. long. and there is your box.
Try Google
Post Number: 7803
did you measure the port lenght from the PIECES of the port wall, or from the exact middle of the port all the way through??
Username: Rvlacos
Post Number: 227
is this a good box for my sub what could be better, whats wrong with it?
Try Google
Post Number: 7804
there is nothing wrong with it. lol
does it sound good to you??? that is all that matters. DD recommends 40hz tuning, and you have it, or close to it. so be happy:-)
Username: Rvlacos
Post Number: 228
i measured it from the wall to the end of the port wall. 17". from the front of the wood to the back wall 11". 4" wide all the way through.
it sounds great and it hit a good number 141.05 so im happy, but who is ever satisfied, lol.
Try Google
Post Number: 7806
then it is as close to your tuning as i can get it:-)
one day, you will get tired of bass(one day), and you will opt for something that isn't as loud an sound very clean and clear, cleaner and clearer than anything you have experienced before, and that will be the system you keep forever:-) lol
Username: Rvlacos
Post Number: 229
have u been metered? also do you hit higher numbers on the windshield or the kick? what do they do at actual comps?
oh and where did u find the xmax? im tryna learn how you did this
Username: Frkkevin
Post Number: 1404
Muddy.. mine was done with port displacement as well..
Hence the:
Total: (total box volume)
Vb: (after port displacement)
Caclulations were made using .75 for port walls and box walls. The port measurements you gave will change what we both said. When asked the port length we meant the actualy length of the port.. in your case how long the wood was that created the L shape
Username: Rvlacos
Post Number: 233
Try Google
Post Number: 7811
i did:
the internal volume
minus the port.
minus sub displacement.
then i got 58sq.in. of port area.
and matched up the length of the walls
...not center diameter like you are supposed to do, but he gave me the measurements i could work with, and i got 41hz....sooo to each their own?? lol
i increased the Xmax until i got the port area i wanted in that program. your Xmax is closer to 16-19mm:-)
Username: Frkkevin
Post Number: 1405
for internal dimensions this was what i posted..
Total: 4.444cu.ft
for external it was completely different
Try Google
Post Number: 7816
this is going nowhere......:-)
Username: Frkkevin
Post Number: 1406
it is.. what im saying is my calculations and yours were similar when i used the internal dimensions for what he gave..
anyway.. like muddy said.. if you like it who cares what the specs are...
Try Google
Post Number: 7818
exactly.:-) lol
Username: Rvlacos
Post Number: 234
thanx guys sorry to make an argument.
muddy have u been metered? also do you hit higher numbers on the windshield or the kick? what do they do at actual comps?
Username: Frkkevin
Post Number: 1407
highers numbers on the kick... legal your numbers will be lower.. (windows up.. doors closed) .. outlaw your numbers will be higher windows or doors open
Try Google
Post Number: 7821
no i havent had the chance to have mine metered.
i was at a local get together a LONG time ago, but didn't have enough time to get mine metered before work. lol
Username: Rvlacos
Post Number: 235
thats how i got metered all window and doors closed and they put the tl meter on the windshield. i guess the shop i go to knows what theyre doin
