Input Signal Voltage....
Username: Timothy_314
Post Number: 269
ok i got the Profile AP2000 amp and a eclipse cd5415 for my Cd player thats 5V preouts and my amp said it was 2.0 to 7V Inputsignal Votage... my q. was where sould i put my gain at? i don't have a DMM or anything like that so please help thanks! :-)
Username: Cenus
4, 20
Post Number: 2418
well this is what you do turn the volume up to 3/4's total volume(ie 25/30volume) then you have your gain at zero, then slowly turn it up untill you hear distortion, then turn it down a little bit, but my guess is it would be around half way up, but thats just a guess.
Username: Bernymac
Rialto, CA United States
Post Number: 673
Why don't you just spend 20 bucks and get a DMM, I know its cheaper than that but $20 average.
Post Number: 272
yeah i should i turned it up all the way but i never heard distortion :-( probably cuz im underpowering it ALOT :-(
Username: Basshead86
Try Google
Post Number: 7755
probably. don't do that again please.
