Question About Clip Light
Username: Shawnomak
Sask Canada
Post Number: 350
My amp hardly ever clips because I have my gains set to what I think is right. There are some songs that make it clip though, and sometimes I don't notice it because I can't see my amp from where I'm driving. I was wondering if I could take my amp apart and run wires from the diode to another l.e.d I can mount in my dash. This way, the light in my dash will tell me if my amp happens to be clipping and I don't have to check the amp.
Username: Extrmndor3
Chicago, Ill Us
Post Number: 2309
yes
Username: Johammbass
Cork, Co.Cork Ireland
Post Number: 360
Nice idea
Username: Basshead86
Try Google
Post Number: 7528
or. you couls cut back the gains
_ <~~ that much and never have to worry about it again.......
Username: Frkkevin
Lake Worth, Texas US
Post Number: 1350
^^ .. you could waste your time adding more wiring and an LED into your dash.. or you could just properly gain match you amp.. all you'll have is a nice clean signal and no more clipping
... unless your voltage drops insanely low for some reason and your amp can't draw the current it needs.. but besides that you'd be set :-)
