Finally!!!
Username: Zoomiebird
Post Number: 42
I gots me an amp! ok i got a couple of questions for the goldmembers (or anyone with knowledge). i got a JBL BP1200.1 and there is a plan brewing to pump noise from my 2 infinity 1030s. First off, how important is expensive as S*IT wiring, and where should i get a fair to good quality wiring kit? secondly i dont want to blow either the amp or the infinitys quite yet so is there one of those RF diagrams to show me how to optimyz (big word i know) my output? I am seaking advice with humble humility, please help.
Username: Bernymac
Rialto, CA United States
Post Number: 499
http://www.rockfordfosgate.com/rftech/wiringwizard.asp
If thats what your asking for. KnuKonceptz has good prices on power wire, if thats what you need. Ebay for amp kits, if thats what you were asking.
Post Number: 43
What i really want is suggestions. if i wanted to i could have found the diagrams on ebay, i just wanted to know whats best. I already have an 800 watt amp running my four speakers. can i just run a little remote wire from it to turn on the jbl as well? should i run a second wire from my battery to my second amp or get a distributer? can anyone answer these daunting questions?
Post Number: 44
is this a good wiring kit for my amp?
http://www.knukonceptz.com/productDetail.cfm?prodID=eKo-K4
Username: Bernymac
Post Number: 503
Depending on how big your power wire is, you could just get the distrubution block. Thats if the wire is like 0awg or close. But if you have 4awg or smaller in diamter, then I wouldn't do a distrubution block on that small of a wire. And yes you can run the remote wire from the one amp to the next, or use a relay.
Username: Bernymac
Post Number: 504
If you want to do a relay, heres a link to a old thread.
https://www.ecoustics.com/electronics/forum/car-audio/275932.html
