Amp for 2 ssd's
Username: Mike_botello
Muskegon, MI USA
Post Number: 38
i just ordered 2 12" fi ssd's the the other day to upgrade from some cvrs and im gunna need an amp so any suggestions. its gunna need to be 1600w rms at 2 ohms.. ive been looking at a few but dont know.. budget is around 300 thanks.
Username: Tdawg30
Ohio USA
Post Number: 336
not gonna happen in that price range. i would also suggest you get 2 amps. it would be much easier.
Username: Tdawg30
Ohio USA
Post Number: 337
this might be your closest bet for the cheapest.
http://cgi.ebay.com/SOUNDSTREAM-PCA2000D-2000W-MONOBLOCK-CLASS-D-AMP-NEW_W0QQite mZ250036464874QQihZ015QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2769
if you want to try this amp
clarion dpx11500.
1500w rms at 2 ohms for 260$
CEA 2006 (according to the seller on ebay)
Class G/H (more efficient than a D)
200A fuse
That's your best bet
Username: Alias747
MN
Post Number: 1402
According to Clarions Website it really is 1500 wrms @ 2 ohm 14.4v. Although that is at 14.4v and those ssd's could use a good 1600 wrms. Good price though.
Username: Juliob
Post Number: 2778
underpowering by 50w per sub is not a big deal
Username: Imperial_designs
Lafayette, Louisiana
Post Number: 9
DD audio M1a will run 440 or so. if you could i highly recommend you save up for one. massive audio P1500.1 is around that price as well and its a great amp also. the soundstream PCA1500.1 is a good amp as well and there about 440 also another option is the cadence Daytona 1600. very strong amp closer to 2K @ 14.5 volts. they run a bit more but you get waht you pay for.
