Whats the advantage (MTX)
Username: Vwbug1971
Warren, Nj
Whats the advantage or reason to buy a mtx 9510-04 instead of a 9510-44. The second has a dual coil...correct?...whats the advantage to that, their the same price so i'm unsure which to buy. I'm looking to run one sub with a mono amp, most likely an mtx thunder 1501D-anyone see a problem with that?
Username: Sploosh56
Post Number: 18
The dual voice coil sub when wired in paralel will give you a 2 ohm load which would be great for the amp that you are looking to buy.
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2793
strictly a matter of matching the load of the sub(s) to the amp(s) you choose to drive them.
