Inverted and subs facing up
Username: Denali_on_22s
Maryville, TN Us
Post Number: 268
Does inverting a sub campen its sound alot? What are the pros and cons to doing it? What about subs firing up? does that affect their sound. I did it once and I thought it did but i wasnt sure
Username: Rovin
Trinidad & T...
Post Number: 9238
http://www.wickedcases.com/caraudio/inverted.html
Maryville, TN Us
Post Number: 270
Thanks rovin... anything on the facing upwards? I know steve meade doesnt have a problem with it but (dont laugh) when i had tw crossfre 12s i laid them facing upwards and could see a lot of difference in output they sounded much softer... i aslo faced the sideways instead on towards teh hatch and that made the subs much quieter... any idea why?
Username: Phuktupbasshead
Phoenix, Arizona United State...
Post Number: 504
acoustics of your vehicle, bro... keep aiming em until you get it right!
my advise is: keep em as far to the back of the vehicle as possible... the further back the better. then, play with your aim... you'll get it right!
Oh, and by the way, I prefer inverted!
Maryville, TN Us
Post Number: 284
word... i thnk i might invert my sub if i get the audioque or the BTL
