How much of a difference does brand make for cables?
Username: Sweatyogre
Erie, PA USA
Post Number: 146
I saw a Tsunami 4 gauge amp kit at Circuit City and at one of the local car audio shops here for around $80. I decided this was rediculous for a couple cables, a fuse, and some terminals. I went with a Legacy 4 gauge kit from eBay for around $35. Will my choice to save money affect my amp's performance at all?
I plan to buy some twisted pair 12 gauge speaker wire from www.knukonceptz.com to run to my subs, which looks to be pretty high quality to me.
http://www.knukonceptz.com/productDetail.cfm?prodID=KAR12BLS
Username: Dustin3
Tigard, OR U.S.
Post Number: 3711
yea. speaker wire really doesnt matter, but knukonceptz makes good wire. :-)
as far as the amp wiring, it really depends. i have never dealt with legacy wiring or have heard much bou them, but i have seen people who have cheap walmart wiring go bad in just a couple weeks. so yes, wiring does matter, but you should definently be fine with the legacy wiring :-)
