Opinions on this combo
Username: Mrendas
Post Number: 24
Would this combo work? 2 12" Diamond Audio D312D4 powered by a Kenwood KAC-9102D
Username: Tdawg30
Ohio USA
Post Number: 221
dont get a kenwood amp. the subs are good, how much do you want to spend on an amp?
Username: Mrendas
Post Number: 25
My budget for an amp is around $200. Im hearing good things about Kenwood though.
Username: Tdawg30
Ohio USA
Post Number: 222
ok get the dual2ohm version instead of dual4. that way you can run a mono down to 2ohm load not 1 or 4 ohms.that being said, get the kicker zx750.1. its like 210 on ebay. will put out over 800 watts rms @2ohm
Username: Tdawg30
Ohio USA
Post Number: 224
http://cgi.ebay.com/06-MODEL-KICKER-ZX750-1-MONO-AMP-750W-REP-KX600-1_W0QQitemZ1 80031860068QQihZ008QQcategoryZ79829QQrdZ1QQcmdZViewItem
Username: Adddisorder
West palm, Florida
Post Number: 899
D3s are nice but kenwood amps are crap period amp budget is a little low so look for used stuff. caraudio.com has a huge classified section.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2557
where are you hearing good stuff from kenwood???
check some kenwood threads here and you'll change your mind.
Get the kicker or just get the dual 4 ohm version and get a cheap hifonics 1206d if you don't want to spend a lot
Username: Mrendas
Post Number: 26
These are the reviews I have seen.
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14933
Username: Andrew571
Post Number: 75
dont get the kenwood amp, i got it and now look - ten months later im in trouble.
Username: Juliob
Post Number: 2561
don't believe those reviews cuz not all of the owners know about car audio, they just go and buy a brand they've heard or seen on Audio shop and stores. Always ask here or somewhere else before buying some brands cuz not all the products are good/bad. There are some exceptions.
Don't buy kenwood hehe.
Username: Mrendas
Post Number: 28
So what your saying is to get 2 12" Diamond Audio D312D2 run them in series- parallel and get a HiFonics BXi 1206D?
Username: Juliob
Post Number: 2578
if they're dual 2 ohm get a kicker zx 750.1
If they're dual 4 get hifonics 1206d or soundstream pca 1000d
Username: 420alldaylong
Post Number: 326
Matt Rendas
Who saying good thing about kenwood.
Username: Mrendas
Florida
Post Number: 36
How about 2 Diamond D312D2 with a PG R15.0:1?
Username: Juliob
Post Number: 2582
^^^^^great setup
Username: Cavsmaxima
New York United States
Post Number: 350
no one is going to say they dont like their stuff when they have it installed. You really cant look at reviews because its hard to find the negative ones.
Username: Troy81
Tavernier, Fl Us
Post Number: 1183
those people with the reviews were running alpine and kicker and mtx, and they think it sounded good so yeah
