Box tuned
Username: Ameboy14
Saginaw, MI
Post Number: 26
Sorry I did a search and couldnt find it, How do you find out what your box is tuned to?, thanks for the help.
Username: Rovin
Trinidad & T...
Post Number: 9122
http://www.the12volt.com/caraudio/boxcalcs.asp
http://www.carstereo.com/help/Articles.cfm?id=31 ...
Username: Ameboy14
Saginaw, MI
Post Number: 27
Thank you for the links, but my box is already built, and I am trying to figure out if there is anyway to find out what it might be tuned to, it's a single 12 ported box.
Username: Rovin
Trinidad & T...
Post Number: 9123
if its pipe or square rectangle ports u can easily measure external dimensions of the box & port & figure it out using those links
but if its slot ported & there r like 2 or 3 port walls in there where u cant see through well its like impossible 2 determine through measuring it urself unless if there is some kinda computer equipment to measure it which im not sure about
heck from experience i can give a close estimate of what a box is tuned to by just listening to it by playing songs that im familiar with ......
