6x9 suggestions just for rear fill
Username: Ccdoggy
Post Number: 46
I have a larger sedan and have already upgraded all my other speakers and moved them off to aftermarket amps (JL E4200 and an infinity amp). i still have 2 channels open on the infinity and i need to replace my 6x9s in the rear.
yes i know 6x9 dont sound the best i have heard the arguments, but thats what i got and i dont have any room for a adaptor to fit there.
I need a moderatly good pair of 6x9s that are in the neighborhood of $85, support somewhere around 100rms and are 4 Ohms. would prefer if it was a 1 way speaker, but it has to come with a crossover or suggest one that i can get.
100rms as that is what my amp is and i never want to have the chance of them blowing on me. yes i also know if i just control it and everything it would be fine, but its more or less a saftey from spending more on speakers later.
Thanks allot for you're suggestions. I prefer to buy off of ebay but am open to shoices otherwise.
Username: Adddisorder
West palm, Florida
Post Number: 831
http://www.wickedcases.com/caraudio/rearfill.html
enlighten yourself^^^^
