Xtant 1001x
Username: Makmillion
MN United States
Post Number: 421
what's your opinion of this amp?
Username: 420alldaylong
Post Number: 184
Very good amp but over priced when bought bran new. good sound quaity
MN United States
Post Number: 424
I can get one for 250... should I? I need at least 1000wrms @ 2ohms and from what I've read it does just that and the amp was rated @ 12v so it might put out more than that?
I wanna know what I'm getting into... before I buy.
Post Number: 187
Jump on it if nothing is wrong with it.
500x1 at 4ohm
1000x1 at 2ohm
10v-15v
MN United States
Post Number: 425
sweeeeeeeeeeeet Upload
im gonna get it then :-)
Thanks for the help! any more info on the amp is appreciated!
Post Number: 188
XTANT x1001 1-Fully regulated PWM power supply.
2-xtant builds its power supplies to use voltage. 3-ranging from 10VDC to 15VDC.
4-current storage inside the amp which power is promise.
5-Multi-layer,extruded heat sink withforced air fan cooling which means plays longer,cleaner and louder.
6-12dB&24dB/octave.
and more just can't remember right now
