Help design my new system
Username: Svtmassa
Post Number: 13
I had 1 10" jl 10w6v2 hooked up to a kenwood kac-9152d and the jl doesnt get loud enough for my taste... or the amp sucks? anyways, i am starting over
I am looking for a 1000w or so rms amp i have in mind
kx 1200.1
jbl 1200
infinity 1211a
pheonix gold xenon 1200.1
I would probably want two 12 inch subs in a ported box. what kind of subs?? i am going for loudness over sound quality i want to keep the subs $200 or less for each one. thanks
Username: Ctmike
Ct.
Post Number: 1738
can you bump up your budget? or you open to buying used/ebay?
Username: Drsmith
Montana USA
Post Number: 599
2 audioque SD2.5's
http://www.audioque.com/aq/order.htm
should be well under budget
Username: Sb2012
Iowa US
Post Number: 257
well the kicker kx1200.1 will actually put out about 1400 watts or so...try 2 AA arsenenals...or
if u wanted to go one 12" for 1000 watts look into an AQ SD2.5...i think it was logan that hit 137.2 with just one and only 600 watts
you could also get an FI Q...which ive heard is better than the 05 xxx...thats sayin a LOT:-)
