TJ's homemade flare port.......
Username: Thomas_g
NM
Post Number: 1679
This r my first flared ports i did it fo tha hell of it cuz i wuz bored today and they turned out pretty good (2 of them)......one is made of regular 4.25 inner diameter pvc which wuz da harder 1 to make, and tha other wuz different kind of pipe(thinner) with an inner diameter of 4.25" also and it came out way better.....o tha black on tha tip on 1 is spray paint....:-)Upload
Username: Thomas_g
NM
Post Number: 1681
and.....tha other easier better thinner 1.....:-)
My homie tigger being nosey as usual....:-)
And should i put a pic of me?? Naw.....:-)
Username: Oglejust
Post Number: 105
how did u get the flare? did u push it against something?
Username: Shawnomak
Sask Canada
Post Number: 347
Or heat it and bend it? That's a good idea, what are the cost differences between pre-made flared ports and pvc pipe of the same length? Sounds like a good way to save some money. Good job man.
Username: Thomas_g
NM
Post Number: 1693
Yup i got dat muthafu*ka like da incredible hulk and bent dat bioch lol jk, ya i got tha idea from someone on hear, and i wuz bored so i tried it and it didnt come out bad, torch dat bioch till it melts a lil then shape it, its not very hard......thanx shawn....
