Fi, SI, JL, DD
Username: Nyyfan13
VA USA
Post Number: 158
alrite 4 subs, all are about the same power ratings.
which of these 4 is overall the best sub?
looking for SQL.
DD2512
JL W6
Fi SSD
SI BM
all in 12"
thanks
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2917
best over all for what goal??
Username: Ctmike
Ct.
Post Number: 1671
i've heard both the jl and dd and both are great, cannot comment on the others though. also, what's your budget, or can you afford any of the above subs with the proper power?
Username: Adddisorder
West palm, Florida
Post Number: 786
just out of those?
Username: Nyyfan13
VA USA
Post Number: 159
brandon, looking for sq but want it loud also.
Username: Ctmike
Ct.
Post Number: 1672
you can add the arsenal to that list to.
Username: Nyyfan13
VA USA
Post Number: 160
just out those 4 please, unless you got another sub in about that power range, then feel free to tell me.
budget for sub and amp is about $500 but could go up to $700 if need be.
Username: Ctmike
Ct.
Post Number: 1673
2512 or arsenal would get the loudest, than the w6. never heard the fi or the bm. you can check there forums for more info on them, i don't think anyone here has heard either. w6 would definatley win in the sq department.
Username: Basshead86
Google is your Friend, FL
Post Number: 5859
it all depends on how much power you plan on giving any of the aforementioned subs.....
the 2512 will take up to 1200-1500wRMS
W6....not sure, dont care. lol
SSD 600-1000wRMS...more with the flatwind coil option.
BM 600wRMS but people throw 1000wRMs to them or so i am told.
Stockbridge, GA USA
Post Number: 2919
sorry, i missed your SQL part.
middy's power comments are true. best to get what you can power best.
W6's are more SQ then SQL subs imo. i'd say the others will be much louder but may not sound as good.
FI stuff is rather new, so i haven't heard much about them. Muddy is big into FI right now, lol. pretty much the new RE without the jacked up prices.
same with the BM's. smaller version of the SI Mags, which are suppose to be really nice.
and the DD stuff, don't know anything about their stuff....
Username: Nyyfan13
VA USA
Post Number: 161
alrite, i think i narrowed it down to an arsenal cause ive heard lots of good stuff about them and the DD 2512.
thanks for the help.
and if anyone wants to keep posting suggestions feel free to.
Username: Sb2012
Iowa US
Post Number: 241
good choices:-)
Username: Nyyfan13
VA USA
Post Number: 162
im leaning towards the arsenal, and i just wanted to know if a phoenix gold xenon 600.1 would be suffiecient for it or shold i get more power.
Username: Nyyfan13
VA USA
Post Number: 163
didnt bump...
Username: Nyyfan13
VA USA
Post Number: 164
still hasnt bumped...
Username: Ctmike
Ct.
Post Number: 1677
it'll be good but they can handle more power. i'd give it about 800-1000wrms.
