Mb quart rce-216 good?
Username: Carco_dr
Post Number: 9
are these speakers good to run with an alpine amp running 75w x 4 @ 4ohm? bridged the amp is 200 x 2 @ 4ohm. Are these good for midbass and not too harsh or abrasive highs? any suggestions or opinions would be great.
Username: Delsole
Post Number: 764
i herd mb quart got bought out a year or so ago so from what i herein only ther older models are good
im not how sure this is but look into it
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2792
you won't get very good mid bass from thoes. mid range and highs are nice. they can be a little harsh. don't know how they would handle 200 watts a side either.
whats your budget??
Username: Delsole
Post Number: 771
wrong amp and speaker need towork on the speeks
whats the budget
Username: Carco_dr
Post Number: 10
can you tell me what is wrong the amp and speakers?
my budget for speakers is about $150-$200 and for the amp about $300
Stockbridge, GA USA
Post Number: 2842
alpine amps aren't the best, but aren't bad. your amp should be fine.
speakers lack mid bass and can be harsh. not bad, but you won't get mid bass from them so don't look for it, lol.
Username: Delsole
Post Number: 830
m b i thought u were runnin each speaker wit 200 watts
Username: Fandim
Reno, Nevada United State...
Post Number: 1353
the RCE 216's are midbass add-ons, you wont be getting any highs from them. :-) I personally am very fond of my set, as they do their job very well.
Username: Fandim
Post Number: 1354
my bad, I was referring to the RCE 164's, lol.
