Bronze Member Username: TutonkaMarathon, Florida Post Number: 17 Registered: Aug-06 | how much does a 12 or 15" crystal compx run,is the 9900 dd's best subs and how much r those and what about a price for the re mt-12,15,18,,,,,,i am basicaly lookin for 18"s 0r 15"s for my suburban right now i have 3 12"s |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 2664 Registered: Feb-05 | from ROE's store, only place i know of that sells Crystal: Crystal CompX 12 - $420 Crystal CompX 15 - $480 DD subs are really expencive. i don't know a lot about DD, but theres a lot of people on here that really like DD. wheres Mu'DD'y at?? lol RE, you'll have to call them and find a local dealer. they don't sell direct anymore, so prices are up to the dealers now. looking for SPL i take it?? |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 19 Registered: Aug-06 | yes i am lol |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 20 Registered: Aug-06 | there all kinda expensive tho lol,is there any chepaer solutions.i only have 3 12" type e's now |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 21 Registered: Aug-06 | and does any one want to buy 3 12" type e's in a box-1.8 cubes each,box is 21" high-48"wide-28"deep and 1 profile ap1000m amp and 1 profile ap600 for about $480 lol |
Silver Member Username: MendonmafiaUSA Post Number: 168 Registered: Aug-06 | thats not enough? my buddy has 2 type s and its probly in the 135 140 range |
Gold Member Username: TheelfkeeperStockbridge, GA USA Post Number: 2671 Registered: Feb-05 | i got a Treo SSI 15 Dual 2 ohm for sale, $300 shipped. just throwing that out there. good mix of SQ and SPL. |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 22 Registered: Aug-06 | ya its ok but i would rather have some more spl,brandon thankx for mentioning that but to tell you the truth i dont have the money for my regular speakers lol |
Silver Member Username: John_washNashville, Tennessee Post Number: 481 Registered: Dec-05 | how much you looking to spend? |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4818 Registered: Aug-05 | the 9900 isn't their "best sub" per say....depending on what you want. it will take 4-8kw, so oyu will need a few amps...and alts. ![]() i think in your case....the 9500's would do the trick. or even the Audioque HD3's ![]() |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 27 Registered: Aug-06 | idk mabee like 300 to 350 dollars but in the future,cuz i dont have no money now,muddy how about the h2's r they expensive |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 28 Registered: Aug-06 | is there a better price i can get on the hd315 other than on the site? |
Gold Member Username: CtmikeCt. Post Number: 1512 Registered: Feb-06 | mike loudon is selling a 15" aa avalanche for $250, i'd try to get that. it'll get loud with great sq. |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 29 Registered: Aug-06 | yea thanks but like i said i dont have the money to spend rite now whatever i do will be in the future |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4842 Registered: Aug-05 | the Orion H2's???? i have no idea how much they are, but i have heard they are sub-par in the SQ dept. that is the cheapest you will find the HDs on their site, b/c they sell direct. ![]() |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4843 Registered: Aug-05 | and you can get the CompX's quite a bit cheaper at www.Ikesound.com and they aren't the older models either. ![]() |
Bronze Member Username: TutonkaMarathon, Florida Post Number: 32 Registered: Aug-06 | ok thanx alot |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4849 Registered: Aug-05 | ![]() |
