Serious sub cut out ?
Username: Cplaya280
Quakertown, PA USA
Post Number: 271
Ok i got 2 12" kicker l7's in a ported box and i hooked it up and i cant even turn the bass up pass quarter way withouth it cutting out its so horrible, I even upgraded my ampkit to a 2 guage cuz i had this problem b4 and it still does it? an other ideas. Could it have anything to do with my alternator not letting me turn the bass up to loud cuz it could ruin it or anything i really need this straigthend out cuz i had a 15" L7 1000rms and it was perfect but i wanted a lil more power so i got 2 12" l7 1500rms but i cant even turn my bass up.
Username: James1115
Ct
Post Number: 6386
sounds like your alt is on teh way out man.
Username: Cplaya280
Quakertown, PA USA
Post Number: 273
its wierd cuz i cant even turn the bass up not even like loud barly at all my 15 was louder but i cant do nottin with this.
Username: James1115
Ct
Post Number: 6387
did it just start to happen when you got this new amp? if you put your old amp back in does it work fine? just to let you know that going from 1000 watts to 1500 watts will only get you about 1.5 db increase which is barely audible. It's really not worth the hastle.
Username: Cplaya280
Quakertown, PA USA
Post Number: 274
yes it did it with the 1000 rms amp to its just as soon as i switched from 1 15" L7 to 2 12" L7's it hasnt been working right. the amp is a zx1500.1 mono and the subs r 2 12" Kicker L7 Dual 2-ohm both in 1 box together
Username: James1115
Ct
Post Number: 6390
are you sure they are wired correctly? sounds like it is sending the amp into protection. better make sure they are wired series/parellel
Username: Cplaya280
Quakertown, PA USA
Post Number: 275
yea it should be wired correctly im pretty sure not postive tho, idk it seems to much of a hazzle for me so what if i would go back to my 1 15" L7 how would teh zx1500.1 go with that becuz i dont really wanna go back and by another zx1000.1 and resell my stuff and so on its to much work. do u think i would blow sub if i hooked the 15" to the zx1500.1?
Username: James1115
Ct
Post Number: 6392
just take the sub's out and check the wiring. http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+2+ohms+x+2
wire them like option # 2
Username: Cplaya280
Quakertown, PA USA
Post Number: 277
the thing is i have each sub running to its on set of terminals so this wiring really doesnt help
Username: Troy81
Tavernier, Fl Us
Post Number: 1006
if your amp isnt one ohm stable then youll have to use option 2
http://www.the12volt.com/caraudio/woofer_configurations.asp
Username: Cplaya280
Quakertown, PA USA
Post Number: 278
yes i know but i have each sub running to its on set of terminals teh box i have has 2 sets of terminals on each side of the box 1 for each sub so how would i wire it correctly like that
Username: Cplaya280
Quakertown, PA USA
Post Number: 282
should i just ingore the one set of terminals and just run both the subs to the 1 terminal?
Username: Cplaya280
Quakertown, PA USA
Post Number: 287
bump
Username: James1115
Ct
Post Number: 6393
yes
Username: Van_man
Boston South, MA
Post Number: 855
Username: Basshead86
Google is your Friend, FL
Post Number: 4767
once again.
NICE CHART!!!
Username: Van_man
Boston South, MA
Post Number: 857
You need to wire both sides like this. ^^Thanks^^
Username: Cplaya280
Quakertown, PA USA
Post Number: 292
alright thanks everybody i found out it was wired incorrect so i wired it up correctly now and it sounds amazing
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 511
how many watts will your amp put out 1700 maybe?
Username: Cplaya280
Quakertown, PA USA
Post Number: 294
yes 1763 it will put it the certificate says
