Alternator question
Username: Steve_collins
Post Number: 164
well i have a jeep grand cherokke and it has a 5.2 liter v8 with a high-output 150-amp alternator. whats the max amount of watts rms i could put on that and thanks a lot
Username: Rick_ross
Post Number: 419
the max u should put on it is 1000 rms but id put 2000 on it
Post Number: 165
so 1000 is the max?
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2666
150A X 13.8V = 2070 watts max
but that doesn't take into consideration the what the car itself needs. generally its said 40-50 amps are needed for the car. so that'll cut you back to around 1400 watts you can pull.
also doesn't consider the effiency of the amps.
Username: Mendonmafia
Post Number: 156
Are you shure 50 amps to run everything im my car seems like not that much i mean i got power seats mirrors 360 watt factory amp power steering tcs scs tons of sh*t idk maybe it does but 50 amps just seems low to me i was thinking maybe 60 to 70 but idk. its just my guess.
