Ma Audio
Username: Jeffkock
Post Number: 56
Is this worth the $.
http://cgi.ebay.com/MA-AUDIO-HK1000D-HK-1000D-CLASS-D-MONO-AMP-BRAND-NEW_W0QQite mZ180021485321QQihZ008QQcategoryZ18797QQrdZ1QQcmdZViewItem
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8666
not really...if ur looking for around 500-600 rms.then yes
Username: Jeffkock
Post Number: 57
What is for around 1000 watts rms at 1ohm?
Post Number: 8667
it is rated @ 17 volts...ur car only runs around 12.8-13.6volts....
and its gonna be really hard to find a good 1000rms for less then $275 unless its used
Username: Cadillacdb
Houston , TX
Post Number: 779
so your looking for a mono block that does somthing around 1000rms at 1 ohm.. how much you looking to spend ?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2022
what you need is hifonics 1206d and those MA are measured at 17 volts so that's pretty hard to reach... i'd only buy their high end stuff.
Username: Jeffkock
Post Number: 58
I don't really want to spend over $350
Username: Juliob
Post Number: 2035
well... get a better quality amp... search soundstream PCA 1000D, lanzar optidrive 1400d, massive p1000...., check if you can find an used kicker, directed audio d2400, and even if you want to save like 100$ bucks get hifonics 1206d.
Username: James1115
Ct
Post Number: 6264
Ask Marshall if he is still selling his JBL bp 1200. as of last night he was. $175-$200 shipped I believe. It's a heck of a deal.
Houston , TX
Post Number: 787
Juliob ... dude, dont tell people to buy Lanzar because Lanzar is Junk and only a decent cheap alternative if you only have a little bit of money and dont wanna be left with Legacy or Pyramid but its still not a option that should be thrown out all the time because the things are junk and this guy is obviously willing to spend enough on a 1000rms amp to be able to get a good one and not some Crap
Houston , TX
Post Number: 788
that JBL would be a good choice or go with a arc Audio Amp but you would have to price shop to find one within ur price range that has the power you need but im sure if you try hard enough you can find one close enough to ur price range or maybe a PPI ... do you have any amps that ur debating netween at this moment ?
