Hifonics BXi 1606D- can it power two 12' kicker L7's?
Username: Stir_fried_beats
I own two 4 ohm 12' kicker L7's, my question is if i can use a Hifonics BXi 1606D amp to power them. Is it possible to wire the two subs to the amp so that they split the 1600 rms 1 ohm load that the amp is capable of producing. The subs run at 750 RMS, any help with this would be greatly appreciated.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1974
the amp is not going to put 1500w rms that's for sure but yeah, the amp can power those subs pretty good... underpowering by less than 100w is not a big issue, you just need to adjust the gain to your preout voltage
