Install sound system in to M-Benz ML350
Username: Gunaa
Post Number: 106
Hi Guys!
I'm planing to install sound system in to my M-Benz ML350. Any Idea is posible or not? because I ask many people and they said "keep the original"
Username: Crayola0
Wisconsin
Post Number: 593
Whats your budget and do u want sq,spl,sql?
Username: Gunaa
Post Number: 107
J@Yme,
I have the KICKER system amp and sub. I want to know if i can do this in to M-Benz ML350.
Thanks for your reply.
Username: Crayola0
Wisconsin
Post Number: 594
o..y not?
Username: Gunaa
Post Number: 108
This is what my plan Keep the original radio(cd player) just intall the amp and sub. any suggestion?
Username: John_wash
Nashville, Tennessee
Post Number: 456
yea you need a line out converter
Username: J_baby15
Kentucky
Post Number: 528
get a good LOC. Check audiocontrol or JL Cleansweep.
