6.5" comp set for a blazer
Username: Alexv305
Tavernier, FL USA
Post Number: 400
What component set would be best in a 2003 Blazer. I want SQ and I want it to be loud too. Budget is less than $200 a pair.
I was thinking JBL P650Cs, Orion P6.2s, Pioneer Premier TS-C720PRS, or Alpine SPR-17LS.
Any suggestions, if you know of a better comp set I would like to know.
Thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8787
crystal sscs..
Username: Alexv305
Tavernier, FL USA
Post Number: 401
how much are they and were can i get them?
Post Number: 8856
not that much at all..check roe and ikesounds
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2815
$165 from Realm Of Excursion's store i think. i got a set going in my brother's truck whenever we can get around to it.
1 word of advice to anyone who has these or are thinking about getting some. open the crossover boxoes and check the lower inductor coil. on mine they were loose so i reglued them down. if you don't, eventually with all the vibration in the car and from sub bass the solder joints can break loose and that will cause damage to one of the drivers for the side that breaks and possible your amplifier too!!
i've also had simular problems with CDT and JL Audio's crossovers...
Post Number: 8857
^^^interesting???
