What to get? i want your suggestions
Username: Jdub454
Post Number: 15
im a guy that wants to start off his new system in his car on a $500-$1000 budget what should i get your suggestions matter (2 subwoofers and 1 amp) (brand,size,watts)
Username: Kravenblood
Ohio
Post Number: 90
2 stroker 102 2000rms dual 2 ohm $400 on ebay 1 amp hifonics xxcolossus 3200 rms at 2 ohms $730 on ebay a little overt budget but itll work lol
theres a pair of 12 starting at 388 no bids yet
Los Angeles, CA USA
Post Number: 4881
subwoofer....2 jl audio 12w3 d2
amp.........kicker kx600.1
that setup should cost you a little over $600. it will not only sound clean but it will pound pretty good.
Username: Cenus
420 , 420 420
Post Number: 2201
kx1200.1 and 2 AA arsenals.
Username: Jdub454
Post Number: 17
i found a JL Audio 12W3v2-D4 is that any comparison to the jl audio 12w3 d2 that you were talking aboutUpload
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3135
that w3v2 is would be a nice sub. they are clean and can get pretty loud.
the reason he suggested the d2 was because w/ the kx600.1 you will need to get a 2ohm load.
if you get the d4's, an orion 600d would be a good choice.
Username: James1115
Ct
Post Number: 6225
the JL's are a nice choice:-) you could do 2-13w3v3's and a 500/1 for under $1000 and it will sound fantastic:-)
Username: John_wash
Nashville, Tennessee
Post Number: 471
u scared me for a sec...but yea i agree. it should make a nice system
Username: 04redmach1
Columbus, GA USA
Post Number: 58
Try looking at the Mass Destruction Sidewinder 12's, and a Massive Audio P1000.1 amp. Great price and gets loud while staying clean.
