Question about 8 ohm wiring for sub
Username: Courtreezy
Post Number: 9
i have a mtx thunder 4500 10" sub and i was wondering if it is possible to wire it to be 8 ohms?
and if it can't, what effects will it have running a 4 ohm sub on 8 ohms output from receiver?
Username: Illuminator
Post Number: 4090
If it's a DVC 4 ohm, then you can do that.
DO NOT run it off the receiver at 4 ohms. You'll damage the receiver.
