Bronze Member Username: JeffkockPost Number: 27 Registered: Aug-06 | I bought a rockford fosgate 1.0 Fared cap from a friend and I don't have the thing to charge it how do I do this? |
Silver Member Username: Rick_rossPost Number: 301 Registered: May-06 | go ask him for the thing to charge it and if he doesnt have it then f*ck him up |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1723 Registered: Feb-06 | ok do this my friend find a test light, wire all the wire from your batterie to the cap but dont wire to the cap just bring it close then connect negative and negative to the amp, then put the first thing of the test light to the cable and the other end or the sharp thing to the cap the light bulb of the test light will come on nd will charge your cap slowly whe the bulb start to dim it mean that your cap its done, the quickly connect the cable form your batterie and the cable to the amps to the cap and your done |
Silver Member Username: Jenifer_contrerasTampa, Florida USA Post Number: 113 Registered: Jul-06 | Jeff Kockarin ,take this ![]() but if w/o BS go to this web, there is cap manual... This link i got from Polo,so all credits to him http://www.stingerelectronics.com/tech_department/supercaps_manual.pdf |
Gold Member Username: IlluminatorUSA Post Number: 3990 Registered: Apr-05 | Ooookaaaaay.... |
Bronze Member Username: JeffkockPost Number: 39 Registered: Aug-06 | lol |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 319 Registered: Jan-06 | Just one question....why did you get a capacitor? They aren't really necessarry |
