Silver Member Username: Mike_anthesCanton, SD USA Post Number: 353 Registered: Aug-04 | which would be louder...im thinkin the atomic...but im not sure... |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 4262 Registered: Aug-05 | Atomic either way...even for SQ. cuz you will never get a hold of Chad if anything ever happens. lol |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1533 Registered: Feb-06 | oh thers an apocalypsis on ebay for 170 he was hittin 147something with a single atomic |
Silver Member Username: Mike_anthesCanton, SD USA Post Number: 354 Registered: Aug-04 | yea lil rob thats the one i was lookin at...he lives pretty close to me...the atomic has better sq than the brahma...wow...i always thought of the atomics as spl oriented subs...hmm...maybe i should sell my brahma and get the atomic...what do u suggest... |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1538 Registered: Feb-06 | ill gethe atomics i have the apxx but i dont have the power to feed it plus its quad .5 ohms hard to wire and yeah its a great sub, if i were u i get the atomic but my apxx have some great sq as well |
Silver Member Username: Mike_anthesCanton, SD USA Post Number: 356 Registered: Aug-04 | how much power do u suggest you feed the apx...i just got a 98 blazer with a 200 amp alt( i just put that in)...i think he said that that apx was a dual 2 meanin i could finda decent 1 ohm stable mono block... |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1542 Registered: Feb-06 | umm get a hifonics bxi2006d ull be happy if u can get an orion 2500d ull be fine too but the orion takes too much current because it has two power suplyys it just like two amps so get an apocalypsisi or the apx and get some good 2000rms+ amp if u dont have the link here it is atomicspeakers why u dont buy some tcsounds??? tcsounds they are great subs great sq and just like eclipse but alot cheaper |
Silver Member Username: Mike_anthesCanton, SD USA Post Number: 357 Registered: Aug-04 | what would you recomend i buy from tc sounds...currently i had my 15" adire audio brahma mk 1 in my blazer and i like it...but i kinda want more...what would you suggest...i guess my budget would be 450 if i sold my brahma... |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1543 Registered: Feb-06 | oh well the tc-3000 i was planning to get it but its quad 1 ohm only and my amps will not support them, it has 35mm of xmax dude thats extremnme u adire audio i think it has around 22-26 mm and the tcsoudns it even better and dont need too much power only 1000 rms to get loud get two of them and some go0d amps |
Silver Member Username: Mike_anthesCanton, SD USA Post Number: 358 Registered: Aug-04 | actually my brahma 15" is a mk 1 and the specs are different form the mk 3(the mk1 had an xmax of 29mm i think)...the mk 3's are not all that great but the mk 1's and 2's(15"s of course) could reach 150db in the right box and vehicle...i was only hittin in the 145 ish range...and id like to hit more...the tc 3000 seems to be out of my price range for 2 of them would one of the tc3000 15"s be louder than 145 or so? |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1544 Registered: Feb-06 | i seend a dude hit 147.9 wiht a tcsounds 3000 and iseen a dude hit 158.7 with a single apxx 15 inch wit like 4000 watts |
Silver Member Username: Mike_anthesCanton, SD USA Post Number: 359 Registered: Aug-04 | so generally the tcsounds3000 is about like my brahma 15...so really i would gain no noticable sound change...maybe ill just add another brahma 15" mk 1... |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1545 Registered: Feb-06 | http://realmofexcursion.com/videos/Atomic/apocalypsex18.1.wmv http://realmofexcursion.com/videos/Atomic/apocalypsex18.1.wmv look at this woofer its the apx and look he put it in the wall outlet at 220v at 92 amp do the amt your self and it like 30k rms and they apx didint broke a a nail regular apocalypsisi with wuatum dust cap http://realmofexcursion.com/videos/Atomic/apocalypse10.1.wmv apocalypsisis http://realmofexcursion.com/videos/Atomic/ap10.1.wmv another apocalypsisis http://realmofexcursion.com/videos/Atomic/apspl10.1.wmv |
Gold Member Username: Extrmndor3Chicago, Ill Us Post Number: 1546 Registered: Feb-06 | welli htink ur only option it some atomic apx or apocalypsis apxx its 360 the apx i dont know the apocalypsiis its like 220 all are 15 |
Silver Member Username: Mike_anthesCanton, SD USA Post Number: 360 Registered: Aug-04 | k ill look into that thanks for all yur help...still open to any other suggestions... |
