What will work
Username: Kenny_hammond
Post Number: 174
I have 2 12 w3 subs and i want to get 2 10's but i dont know what kind i dont want to spend more than 150 on each sub would kicker or cerwin vega sound good. I will have a small sealed box i can look up the specs if need to ( how or what do i look for in a good sub like the freq. or ?)
Username: Showrides
Hartford, CT USA
Post Number: 130
Well first off decide how much power you got to work with. Then decide if you want SPL, SQ, or SQL. I am guesisng you will want something that sounds good, but still hits pretty loud. Let me know if that sounds right then let me know about how much power you got to work with and I can help you out.
Post Number: 175
yeah that sounds great i dont know how much power i have to buy a amp
Username: Showrides
Hartford, CT USA
Post Number: 131
Then give us a budget to work with.
Post Number: 177
i want to pay 150 a piece for subs and about 300 for amp i have a box setup so i need a amp and sub
Username: Showrides
Hartford, CT USA
Post Number: 132
Got room for 12's? Or are 10's your only option?
Post Number: 178
i can put 12's but i have a xtra cab truck and i have always heard that 10's would sound better i have a pair of 12w3's in my room that f*cke n bang hard should i stick with them?
Username: Showrides
Hartford, CT USA
Post Number: 133
12's will sound just as good as 10's as long as you have enough room for them. Let me know how much space you have to work with and I will tell you if the 10's would be a better choice.
Post Number: 179
hear is the box i am using http://caraudiofactory.com/942001-dodge-extended-p-76.html or i can use this one http://caraudiofactory.com/19942001-dodge-extended-p-75.html
Username: Basshead86
Google is your Friend, FL
Post Number: 4109
i would get some Image Dynamics ID's or IDQ's.
they work well in smalllllllllllll sealed enclosures.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1484
haha
Post Number: 181
whats the ha ha for?
Username: Showrides
Hartford, CT USA
Post Number: 134
These 12's would work great.
http://www.low-hz.com/commerce/catalog/product_info.php?cPath=21_25&products_id= 31
These 10's or 12's would also work just fine in either of those 2 enclosures.
http://www.low-hz.com/commerce/catalog/product_info.php?cPath=21_33&products_id= 49
http://www.low-hz.com/commerce/catalog/product_info.php?cPath=21_33&products_id= 50
Let me know if you like any of those. I have used both drivers personally and they both sound very good.
Post Number: 183
they look good but do they sound good and clean and will they play better than cvr's
Username: Showrides
Hartford, CT USA
Post Number: 135
I would say the 187's would be the best choice. I had them hooked up in small sealed enclosures, and was giving them about 300rms each and they sounded really good. It is a very good overall SQL driver.
Post Number: 184
which subs are u talking about? and what amp should i get?
