Which would be louder?????
Los Angeles, CA USA
Post Number: 4497
who do you think you can hear from farther away.
2 18" subs in a mini cooper or 2 18" subs in a tahoe.
same system in both cars with the box built to sub's specs.
my friend thinks the tahoe will get louder outside cause it will hit deeper than the mini cooper.
i think the mini cooper will get louder.
now i am talking about hearing the bass outside the car not inside.
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 569
tahoe, becuase the resonating frequency is lower and since lower notes travel farther, you will be able to hear it from farther away.
but their are so many factors that would alter it so it really depends
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 8270
^^Right...but the mini will get lots louder..i bet it peaks around 60hz
Username: Theweasel
Post Number: 571
but if you were right next to the mimi cooper it would sound louder, and you'd probably have so much rattling it would be louder than the bass notes, lol.
