Best 10 inch subs
Username: Vtchevy
i'm looking for 2 10inch subs to put under the rear seat in my silverado. here are some of the subs i've been looking at.
jl w6v2
RE sx
kicker L7
kicker crx
alpine type-r
i've also thought about raising the rear seat so i could fit 2 jl w7. would it be worth the work or should i just get something else? what is everyone's suggestions.
Username: Vtchevy
i want it to be loud as f!ck but also have good sound quality
Username: Pitchblack
Post Number: 7
IF u could fit the W7 thats your best bet!! but if not then depends how much u want to spend.
Username: Vtchevy
between $200-$300 for each sub
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 565
what direction do you plan on firing the subs? towards your feet?, towards your @ss?
Username: Vtchevy
down fire, i've heard that is the best for a truck
Post Number: 568
is you back seat a bench seat?
Username: Vtchevy
yea, bench
Post Number: 570
do you use it?
Username: Vtchevy
yea i want to keep the seat,
also what about diamond d9 or eclipse ti
i would have to raise the seat.
Username: Vtchevy
Post Number: 7
which is the best in a sealed box, loud but good sound quality
RE sx
jl w6v2
diamond d9
eclipse ti
kicker L7
kicker cvx
alpine type-r
Username: Kenny_hammond
Post Number: 180
i have always hear the cvr's are the best sealed
Username: Udai
Post Number: 158
Im not sure about most of those
but the SX is not a sound quality sub.. same with the l7. And the w6v2 has AMAZING sound quality, i hear the diamond audio d6 is directly compared to the w6v2, so i assume the d9 would be similar (just alot louder)
Username: Sb2012
Marshalltown, Iowa United states
diamond d9...i know a guy that hit 138 dbs with one 12" ported and kicker 1250.1 amp running it...and it sounded great...ud be very happy with 2 10" d9's...more sql than anything tho
Username: Frkkevin
Denton, Texas US
Post Number: 309
whoever says SX are just pure spl are crazy lol.. you'd be quite suprised for how good they sound.. but back on the subject. you can port the box for under your seat but you'd have to build a raised false seat... guess its a trade off for getting loud. i just did away with the whole back seat, figured if ima have more than 2 passangers they can ride in the back of the truck :-) ..
