Tricky 1/2 ohm wiring
Username: Tman86
I have a 2 channel boss pd-3000 amp and i need to wire it in a 1/2 ohm to a HK12X2 that has dual voice coils. how do i do this...?
Username: Alexv305
Tavernier, FL USA
Post Number: 281
first throw away the boss then well help u from there...
Username: Carguy
Post Number: 5603
1/2ohm load will depend on your sub's VC configuration. If it's a pair of 2ohm DVCs, then those wired in parallel will give you 1/2ohm.
Username: N2audio
Lawrence, Ks USA
Post Number: 928
if you just have the 1 sub, and it's a dual 2 ohm voice coil it can only be wired for 1 or 4 ohms.
