Amp for 12 re xxx
Username: Sunnyice
Post Number: 20
can you guys suggest me any amps to power this beast?
Username: Rovin
Trinidad & T...
Post Number: 8597
2005 or 2006 model ???.....
Username: Sunnyice
Post Number: 21
ok, im just a noob, whats the difference between these two?
Username: Sunnyice
Post Number: 22
oh it's gonna be a 06 model
Username: Rovin
Trinidad & T...
Post Number: 8599
rated @ 2000wrms 2 ohms dvc right !?
a good 2500wrms @ 1ohm amp on it .....
Username: Sunnyice
Post Number: 24
can you suggest me any cheap good brand?
Username: Alias747
MN
Post Number: 1132
Orion 2500D is your best bet.
Heres some:
http://cgi.ebay.com/Killer-ORION-2500D-single-chanel-D-class-amp-2500-Watts_W0QQ itemZ330008875809QQihZ014QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/ORION-2500D-MONO-D-class-amp-2500-Watts-RMS-5000- PEAK_W0QQcmdZViewItemQQcategoryZ38638QQihZ018QQitemZ280009429268QQrdZ1QQsspagena meZWDVW
http://cgi.ebay.com/ORION-2500D-CLASS-D-AMPLIFIER-BRAND-NEW-RAW-POWER-NR_W0QQite mZ250010517557QQihZ015QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
http://cgi.ebay.com/Orion-1-channel-2500D-amplifier_W0QQitemZ160009455698QQihZ00 6QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Happy Hunting! :P
Username: Showrides
Hartford, CT USA
Post Number: 92
I got a Massive Audio P3000.1 and a US Amps md2 laying around if you are interested. The Massive audio amp will give you 3000rms at 1 or 2 ohms, and the MD2 will give you around 2000rms at 1 ohm.
Username: Alias747
MN
Post Number: 1135
I am not sure about the Massive Audio. But US Amps makes really good shit. Go for that.
Username: 04redmach1
Columbus, GA USA
Post Number: 22
Massive Audio makes a nice product and rated right. With a 2 year warranty, HARD TO BEAT. OH and so you know, P3000.1 was benched at 3150 RMS
Username: Skies
Courtenay, British Colu... Canada
Post Number: 223
Both are GREAT companies....
I believe his amps are used though, so no warranty?
Go with the Massive amp... They are beasts..
