Archive through June 09, 2006
Username: Spayde
Hey can someone please help me with the wiring codes for a 94' intrepid. Also I see here that you keep putting "constant 12V" and "switched 12V". Which wire from my Pioneer CD Player would I hook up to the the "constant 12V", "ACC (Red)" or "battery (Yellow)". I am also left with one wire left over... Sorry if those are stupid questions. My dash lights and tail lights are no longer working once I hooked up the CD player that is why I need help, which wire would control these, or could I have blown a fuse.
Username: Dj_d3cib3l
Does anyone know the wiring schematic for a 1994 Honda Accord EX Sedan and a 1999 Honda CRV? Also, would I be able to buy harness adapters that plug into the OEM harness and have bare wires on the other end at a place like Auto Barn or Pep Boys? I want to keep my OEM harnesses intact, but I also need the raw end adapters by saturday and cannot wait 5+ business days for ebay sellers. Thanks!
Username: Nypdlapd
Ontario Canada
Post Number: 434
Eric, u can get an aftermarket harness from pepboys and stores like that,BUT i don't no if they have the OEM...
Accord
A Right Rear Spkr (+) Red w/ Yellow Stripe
Left Rear Spkr (+) Blue w/ Yellow Stripe
Power Antenna Trigger Brown w/ White Stripe Blue
+12 Volt Ignition Wire Yellow w/ Red Stripe
Right Rear Spkr (-) Brown w/ White Stripe
Left Rear Spkr (-) Gray w/ White Stripe
Ground Wire Black
+12 Volt Battery Wire White w/ Yellow
Left Front Spkr (+) Blue w/ Green Stripe
Right Front Spkr (+) Red w/ Green Stripe
Left Front Spkr (-) Gray w/ Black Stripe
Right Front Spkr (-) Brown w/ Black Stripe
CRV::
Constant 12V+ White/Blue
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer Red
Front Speakers
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Username: Nypdlapd
Ontario Canada
Post Number: 435
Doug you would hook up the constant to the YELLOW wire,and switched to the RED
Right Rear Spkr (-) Blue w/ White Stripe
Left Rear Spkr (-) Brown w/ Yellow Stripe
Right Front Spkr (+) Purple
Left Front Spkr (+) Dark Green
Right Rear Spkr (+) Blue w/ Orange Stripe
Left Rear Spkr (+) Brown w/ Blue Stripe
Power Antenna/Amp White (use for Infinity Radio)
+12 Volt Battery Wire Pink or Pink w/ White Stripe
+12 Volt Ignition Wire Red w/ White Strip
Right Front Spkr (-) Blue w/ Red Stripe
Left Front Spkr (-) Brown w/ Red Stripe
Metal Braid Or Plastic Connector Attached To Back Of Radio Is The Ground Wire
Black
Username: Spayde
Thanks a lot, but I also have an orange wire coming from the car, that I have no use for. Should I just tie it off? I connected the braid to the back of my CD player but the car also has a black/gold stripe cord (I believe.)should I attach that to the black ground wire from my CD Player? You've been a huge help, thanks.
Username: St4l1n
Redding, CA USA
Just replacing the factory deck on my 99 C280 Benz, I noticed you had a post of the '90 E series and I was wondering if that diagram also applies to my deck? Thanks!
Post Number: 8
Thanks for the wiring info. The harness I need is an aftermarket harness. I just need one that plugs into the original one and has bare wires on the other end so that I wont have to splice the wires on the original harness.
Username: Nypdlapd
Ontario Canada
Post Number: 437
1999 Mercedes C-Class
Constant 12V+ Pink/Green
Switched 12V+ Red/Blue
Ground Brown
Illumination n/a
Dimmer Gray/Blue
Antenna Trigger Blue/White
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Green
Left Front (-) Brown/Green
Right Front (+) Orange
Right Front (-) Brown/Orange
Rear Speakers 6 1/2" Rear Deck
Left Rear (+) Pink
Left Rear (-) Brown/Pink
Right Rear (+) White
Username: Nypdlapd
Ontario Canada
Post Number: 438
Eric yes the aftermarket one plugs in and it has the wires spliced
Username: Thebum
how about a 1997 hodna accord lx? I need to doublecheck the installation, some of the connections are definitely wrong. I'm sorry if it was already on the page and I'm just oblivious. Thanks.
Username: Thebum
mmm, hodna audio wiring...
Username: Thebum
Yeah, that was definitely supposed to be honda
Username: Tjmutlow
Post Number: 2070
Information )
1997 Honda Accord Stereo Information
Constant 12V+ Yellow/White
Switched 12V+ White/Red
Ground Black
Dimmer n/a
Antenna Trigger Yellow/White
Antenna Left Rear
Front Speakers 5 1/4" Doors
Left Front (+) Blue/Green
• Alarm Information • Cruise Information
Username: Tjmutlow
Post Number: 2071
eric go, the harnesses are common harness for those hondas, any car auduio shop would have them...
Username: Phatty34
also whenever i turn on the dash lights the gear lights dim but no dash lights come on and then when i switch them off the gear lights light up again.
Username: Nypdlapd
Ontario Canada
Post Number: 443
take off the dimmer wire!!!
Username: Phatty34
from the cd player? i have everything disconnected no fuses are blown to my knowledge is there any specific duse under the hood that could cause them not to work? i looked in the manual and it doesnt show any just fuses to the head lights its for a 99 isuzu rodeo
Username: Tjmutlow
Post Number: 2089
you need to take a test light, and teset every fuse(both sides of the fuses)
Username: Qslimms
Swanton, Oh Usa
Post Number: 49
anyone gotta wiring diagram for a 99 mitsubishi diamante
Username: Zogan
i was wondering if anyone had the wireing color for a 97 Jetta it would be alot of help
Username: Thebum
thank you master mutlow
Username: Tjmutlow
Post Number: 2102
1997 Volkswagen Jetta Stereo Information
Constant 12V+ Red/White
Switched 12V+ Gray/Blue
Ground Brown
Illumination n/a
Dimmer n/a
Antenna Left Front
Left Front (+) Blue/Black
Left Front (-) Orange/Blue
Right Front (+) Red/White
Right Front (-) Orange/White
Left Rear (+) Red/Light Green
Left Rear (-) Orange/Black
Right Rear (+) Blue/Light Green
Right Rear (-) Orange/Red
Username: Koz67
New paltz, Ny USA
I am looking for the wiring color codes for 98 dodge stratus to figure out whats what for the radio
Username: Motonut427
could someone please show me the wiring diagram for a 1996 f-150 with the lowest sound package? It's a fleet side truck. thanks!
Username: Tate89
1998 ford escort lx
Username: Tate89
1998 ford escort lx audio wiring
Username: Girlie
1995 Ford F-150 wiring?
Username: Tjmutlow
Post Number: 2104
1998 Dodge Stratus Stereo Information
Constant 12V+ Pink/Yellow
Switched 12V+ Red/White
Ground n/a
Illumination Orange/Brown
Dimmer Black/Light Blue
Antenna Trigger Orange/Red
Antenna Right Rear
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Username: Tjmutlow
Post Number: 2105
1996 Ford F Series Stereo Information
Constant 12V+ Green/Purple
Switched 12V+ Yellow/Black
Ground Black/Light Green
Illumination Light Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Left Front (+) Orange/Light Green
Left Front (-) Light Blue/White
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 6" x 8" Side Panels
Left Rear (+) Gray/Light Blue
Left Rear (-) Tan/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Username: Tjmutlow
Post Number: 2106
1995 Ford F Series Stereo Information
Constant 12V+ Green/Yellow
Ground Red or Black
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Username: Tjmutlow
Post Number: 2107
1998 Ford Escort Stereo Information
Constant 12V+ Blue/Red
Switched 12V+ Blue/Black
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Driver's Pillar
Left Front (+) Purple
Left Front (-) Blue/Orange
Right Front (+) Blue/White
Right Front (-) White
Rear Speakers 6" x 8" Rear Deck
Left Rear (+) White/Blue
Left Rear (-) Red/Blue
Right Rear (+) White/Green
Right Rear (-) Blue
1998 Ford Escort ZX2 Stereo Information
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Right Rear
Right Rear (-) Blue
Username: Girlie
Thanks Ty! What about a 1994 Maxima?
Username: Dp3069
yo i really need help with my 1990 nissan 240sx
Username: Tjmutlow
Post Number: 2109
1994 Nissan Maxima Stereo Information
Constant 12V+ Red/Black
Switched 12V+ Blue
Ground n/a
Illumination Red/Yellow
Dimmer n/a
Antenna Right Rear
Front Speakers 4" x 6" Doors
Left Front (+) Blue/White
Left Front (-) Blue/Yellow
Right Front (+) Brown
Right Front (-) Brown/White
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Username: Tjmutlow
Post Number: 2110
1989-90 Nissan 240 SX Stereo Information
Switched 12V+ Blue
Ground Chassis
Illumination Red/Blue
Dimmer Red/Yellow
Antenna Trigger Black/Red
Antenna Left Rear
Left Rear (+) Red
Left Rear (-) Green
Right Rear (+) Blue
Right Rear (-) Pink
Username: Nelrubio007
I need help with my Toyota Cressida 1991
Username: Drift247
NY
Post Number: 11
any one have the wire code for a 91 ford escort?
Username: Wes_horses
DO YOU KNOW HOW TO RESET SECURITY CODE FOR A KENWOOD KDC-519 SO IT WILL START WORKING?
THANKS,WES
Username: Phatty34
Post Number: 7
i need help!!! i have a 1999 isuzu rodeo and the factory wiring end has been cut off i then wired it directly to the cd player as a result. i have lost dash lights since then. the fuses are all fine and no wires are touching each other how would i check the fuses with the test light and there isnt any fuse under the hood that is labeleed for interior lights. is there a inline fuse that rodeo would have put in and if so would you know where?
Username: Amcchio
need some help,I installed a new stereo in a 90 Escort and it wouldnt work so I switched back to the factory stereo and now it doesnt work either,the fuse is good,,,any suggestions?
Username: Lbrand
Can anyone help me out?
Got my hubby a CD player for his 2003 F-150 supercab. Thought I did so well, getting dash kit and harness... BUT... found out when he gets the dash all torn apart, that the guy at the store sold me the wrong harness (Scosche FD23B).
So I call Scosche, they tell me to get FDK106. Still not right. One of the plugs fits, but theres a square plug with 20 pins - lined up in rows - 7/6/7 that doesn't match up to anything.
What are we missing? What does this plug's wires hook to? I'm stumped and can't even find wiring info anywhere.
Any help you can provide is appreciated.
Username: Jeanhackman
Hi - Hope s'one can help. I am in desperate need of wiring info for an S-reg Ford Fiesta Zetec.
TIA
Username: Sport_4693
Wiring diagram for a 1991 Ford Ranger (Radio) what does all the color mean and what are they
Username: Nameddriver
i have a 1992 supra with the optional 10 speaker sound system and amp, im upgrading the original head unit to a cd player, there is no apdapter for it and i just cant make head nor tail of the wiring system, the original head unit is a fugitsu ten - 86120 - 2b320, please help.
Username: Zteb
I am looking for the Alarm wiring guide with remote start for a:
2006 Ford F-150 Lariat Crew Cab 4x4 with 5.4L
Thanks for your help!
Username: Buddha2007
Belmont, NC US
Hey whats goin on, I need some help, im tryin to put a new radio in my 91 ford aerostar, its a Kenwood KRC-207s, and i can not figure out how to splice the wires, can anyone help me? Or can it even be done? I would appreciate any help. thnx
Buddha
Username: Tjmutlow
Post Number: 2126
1991-92 Ford Ranger Stereo Information
Ground Chassis
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Rear Speakers 5" x 7" Rear Wall
Username: Tjmutlow
Post Number: 2127
1991 Ford Aerostar Stereo Information
Ground Red or Black
Dimmer n/a
Antenna Trigger Orange/Blue
Antenna Right Front
Front Speakers 5" Dash
Rear Speakers 3 1/2" Tail Gate
Username: Tjmutlow
Post Number: 2128
03 f-150, funny casue went to scosche website and wire harness is the FD-16
Username: Tjmutlow
Post Number: 2129
1991 Toyota Cressida Stereo Information
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Right Rear
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
Username: Tjmutlow
Post Number: 2130
1991-93 Ford Escort Stereo Information
Ground Red
Dimmer n/a
Antenna Trigger n/a
Front Speakers 5 3/4" Doors
Left Front (-) Blue/Light Green
Right Front (-) Green/Yellow
Rear Speakers 4" Side Shelves
Username: Combo65
I need the stereo color codes for a 2006 Ford Ranger.
Username: Jboyerv
I need the stereo color code for 1998 Nissan Altima GXE, thanks.
Username: Tjmutlow
Post Number: 2134
1998 Nissan Altima Stereo Information
Constant 12V+ Pink
Switched 12V+ Blue
Ground Vehicle Chassis
Illumination Red/Green
Dimmer Red/Yellow
Antenna Trigger Green/White
Antenna Right Rear
Left Front (+) Brown
Left Front (-) Black/Red
Right Front (-) Black/Yellow
Left Rear (+) Orange
Left Rear (-) Black/Pink
Right Rear (+) Blue
Right Rear (-) Black/White
Username: Essadis911
Calgary, Alberta Canada
need color set up for a 1992 S-10 Blazer if anyone can help thanx
Username: Jonthegr8tone1
Dsm, Ia Us
i need help for a plymoth neon wiring don't know what is what.
Username: Helpless6767000
I need the wiring diagram for a 98 Mirage, i searched and it says it on here, but i cant seem to find it.
Username: Jerkywyz
Queens, Ny USA
Hey Guys, I need Help I have a 1991 Ford Explorer
Was looking for a wiring diagram or maybe the color codes.. Thanks For your help
Username: Phatty34
Post Number: 8
i have a 1999 isuzu rodeo and the factory wiring end has been cut off i then wired it directly to the cd player as a result. i have lost dash lights since then. the fuses are all fine and no wires are touching each other . how would i check the fuses with the test light and there isnt any fuse under the hood that is labeled for interior lights. is there a inline fuse that rodeo would have put in and if so would you know where? Also this may halp when i turn the switch to tun on my dash lights the gear lights dim from a bright green to a very light barley visible green. The gear lights are the only ones on the dash that do work.
Username: Tjmutlow
Post Number: 2146
go to each fuse, on each fuse there are 2 sides(2 metal pieces on top) to it, test both sides of fuse, it may be blown in the middle, allowing current in but not out.
Username: Tjmutlow
Post Number: 2147
1990-91 Ford Explorer Stereo Information
Ground Black
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (-) Blue/White
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (-) Brown/Yellow
Username: Jef
i just bought a 1991 Toyota Celica GTS and the guy who had it mutilated the stereo harness. i need the color codes to re-wire it. if someone can get these it would be great.
Username: Tjmutlow
Post Number: 2150
1990-93 Toyota Celica Stereo Information
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Left Rear
Front Speakers 4" Dash
Left Front (+) Pink
Rear Speakers 5 1/4" Side Panels
Left Rear (+) Black
Right Rear (+) Red
Username: Jakoswald
I have recently purchased a new head unit for my 2001 Pontiac Sunfire. And am now having trouble with the installation as far as wiring goes. I am unable to find the switched 12V+ wire. If someone could please list a wiring guide for my stereo it would be much appreciated. Thank you.
Username: Cb302
Santa Fe, NM USA
looking to ger a wireing breakdown on a 85 LTD Crown Vic it is an odd 5 wire system like I have never seen before would love any ssistance i could get
thanks
Chris
Username: Phatty34
Post Number: 10
can anyone give me the wiring diagram for my dash/illumination lights for a 1999 isuzu rodeo
Username: Zeroredemption
Can anyone get the Radio wiring diagram for a 1985 ford Crown Victoria Ltd? I would be most thankful
Didnt see Chris had already requested it sorry about that
Username: Cb302
Santa Fe, NM USA
ok I got most of it figured out I think. Would still love a color spec, but a new problem arose. I got it wired together and now my speakers will not work with either the original stereo or the new stereo. Any tricks to figure it out would be greatly appreciated.
Thanks,
Chris
Username: Jimbo81
does anyone know whether the alpine TDA-7572R Head unit is compatible with the KCA-420i iPod adapter???
Username: Sports4johyb
Gardiner, Maine
i have a 1995 ford f-150 with original equipment stereo with cassette and am installing a sony stereo. does anyone know the wiring systems from the ford? the ones above dont match up
Username: Tjmutlow
Post Number: 2158
buy the aftermarket harness for it, here is the colors
Ground Red or Black
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Username: Mike330759
hi there ive put a new stereo in my car but it keeps blowing the tail light fues im in need of some help
Username: Mystax
Assiniboia, Saskatchewan Canada
Post Number: 9
1999 acura integra wiring
Username: Geeker
Post Number: 124
1990 crown victoria stereo wiring please.
Username: Quibble
I'm just replacing the head unit on a Ford Explorer 2002 XLT - I have the Haynes wiring diagram for the radio. But I don't know where to wire the existing "vehicle speed" & "air bag contact" wires that were connected to the original Ford Unit.
Username: Tjmutlow
Post Number: 2163
quibs, what are yu replacing it with, if aftermarket, buy the aftermarket harness that adapts your factory harness and then attaches to the radio harness.
Username: Tjmutlow
Post Number: 2164
1999 Acura Integra Stereo Information
Constant 12V+ Blue/White
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Left Rear
Username: Tjmutlow
Post Number: 2165
1990-91 Ford Crown Victoria Stereo Information
Ground Chassis
Dimmer n/a
Antenna Right Front
Username: Tjmutlow
Post Number: 2166
Stereo Information )
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Left Rear
Username: Beblnde
1980 Olds Cutlass Supreme - need wiring info, online wire to wire I found isn't right. have pink, gray, yellow, gray wires (non speaker)from dash and blue w/brown stripe, orange w/blue stripe (says IILUM), red w/blue stripe and yellow from deck plug. Also have gray with a big blob on the end from car. Hooking up Alpine CDE 9843
Username: Becks
Rt, Rt Aus
hi i need Toyota Cressida 1990 help asap!
im attaching a cd player, the toyota harness colors go like this:
(from left to right, top to bottom)
(Black, Blue, Brown) (Blue/Black, Orange, Pink/Blue)
(Green, Yellow, Red, White) (Grey/Black, White/Green, Black/Red)
also, my cd player harness has Yellow(battery) and Red(Acc), where to i attach these to???
Thank you ty_mutlow
Username: Kcbee42
Need wiring colors for a 94 Dodge shadow. Thanks.
Username: Tjmutlow
Post Number: 2172
1990 Toyota Cressida Stereo Information
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Right Rear
Left Front (+) Pink
Left Rear (+) Black
Right Rear (+) Red
Username: Tjmutlow
Post Number: 2173
1994 Dodge Shadow Stereo Information
Constant 12V+ Red
Ground Chassis
Illumination n/a
Dimmer Orange/White
Antenna Right Front
Left Front (-) Green/Yellow
Right Front (-) Purple/Yellow
Rear Speakers 5" x 7" Side Shelves
Left Rear (+) Brown
Right Rear (+) Blue/Red
Right Rear (-) Blue/White
Username: Kcbee42
Wow, fast reply, ty so much....
Username: Jeepin
Does anyone know the wiring code for a 97 jeep wrangler. Thanks
Username: Tjmutlow
Post Number: 2185
1997 Jeep Wrangler Stereo Information
Constant 12V+ Pink/White
Switched 12V+ Pink
Illumination Orange
Dimmer Black/Yellow
Antenna Right Front
Front Speakers 4" x 6" Dash
Left Front (+) Brown/Red
Rear Speakers 5 1/4" Roll Bar
Left Rear (-) Brown/Blue
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
Username: Beblnde
Ty, any luck on the 1980 Olds Cutlass Supreme wiring? my 17 year old son would love to get his deck working.
Thanks
Username: Jakoswald
Need help with wiring for a pontiac sunfire 2001. Any post to coloring would be much apprieciated.
Username: Tjmutlow
Post Number: 2186
dee, sorry nothing
Username: Tjmutlow
Post Number: 2187
could not fiond 01, but maybe 00 would be same...
2000 Pontiac Sunfire Stereo Information
Constant 12V+ Orange
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Right Rear (-) Light Blue
Username: Jakoswald
Thanks a bunch Ty.
Username: Lady_t17
Post Number: 7
Do n e 1 know the right wiring for a '99 special edition ford contour so i can get this stinkin radio in that raggedy car cuz it's driving me insane!?! my wire harness was cut out and the wires r different from whats been given to me... i got the colors listed on the forum...would somebody please help a fellow driver regain some music for the road
Username: Johnstanger
Layton, UT USA
I have a 2002 Saturn SL1, I'm trying to install a Dual XM stereo, but there are some wires coming from my saturn that i dont recognize. can you help me ty
Username: Detroitd741
i have a 1993 ATURN I NEED HELD WITH THE WIRES I AM TRYING TO HOOK UP A SONY CDXC620,AND A SANY AMPA 1502 SX . WHAT WIRES DO I HOOK THE TRADIO UP TO AND WHRE WOULD BE A GOOD PLACE TO GROUND THE AMP IT KEEPS ON SHUTTING OFF. AND THE LIGHT DISPLAYS "OFFSET" WHAT F------ GIVES. PLEASE HELP
Username: Tjmutlow
Post Number: 2207
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V |red |+ | ignition harness |
| STARTER|yellow |+ |ignition harness |
| IGNITION|pink |+ |ignition harness |
| SECOND IGNITION|green |+ |ignition harness |
| THIRD IGNITION|lt grn (key sense)*7|- |ignition harness |
| ACCESSORY|orange |+ |ignition harness |
| SECOND ACCESSORY|brown |+ |ignition harness |
| POWER LOCK|orange/black |+ |drivers kick panel |
| POWER UNLOCK|red/black |+ |drivers kick panel |
| LOCK MOTOR|gray | |drivers kick panel |
| UNLOCK MOTOR|tan | |drivers kick panel |
| DISARM DEFEAT|tan | |passengers kick panel |
| PARKING LIGHTS +|brown | |steering column |
| HEADLIGHTS|blue *6 |- |steering column |
| DOOR TRIGGER|*1 |- |*2 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|red/black |- |BCM, gray 24 pin plug *2 |
|TRNK/HTCH RELEASE|black |+ |switch *4 |
| TACHOMETER|*3 | |*3 |
| SPEED SENSE| | | |
| BRAKE WIRE|lt blue |+ |brake switch |
| HORN TRIGGER|black |- |steering column |
| WIPERS|green(L), purple(H) |+ |steering column |
| LF WINDOW UP/DN|dk blue - brown |A |switch in center console |
| RF WINDOW UP/DN|blue - brown |A |switch in center console |
| LR WINDOW UP/DN|dk green - purple |A |switch in center console |
| RR WINDOW UP/DN|lt green - purple |A |switch in center console |
| SUN RF OPN/CLOSE|not recommended | | |
| SUN ROOF LIMIT|not recommended | | |
| RADIO 12V|orange |+ |radio |
| RADIO GROUND|black |- |radio |
| RADIO SWITCH|yellow |+ |radio |
| RADIO ILLUMINATE|brown |+ |radio |
| LF SPEAKER|tan - gray | |radio or amplifier *5 |
| RF SPEAKER|lt green - dk green | |radio or amplifier *5 |
| LR SPEAKER|brown - yellow | |radio or amplifier *5 |
| RR SPEAKER|dk blue - lt blue | |radio or amplifier *5 |
Notes:
NOTE: This vehicle has the passlock II immobilizer system that, when adding a remote start, must be interfaced with. Use DEI part 555t or 555L. *1 The drivers door is gray/black. The other doors are black/white. Both wires are in the gray 24 pin plug at the BCM. Use both wires and diode isolate each. *2 The BCM is located above the glove box. *3 On the 4 cylinder models, use purple/white at the ignition module on the driver side of the motor. On the 6 cylinder models, at the ignition coils on top of the cylinder head on the drivers side of the motor, use any one of the three wires that is not pink or black. *4 Can also use black/white (+) at the BCM in the gray 24 pin plug. *5 The amplifier in under the driver side dash above the brake pedal. *6 Low beam is high current negative, must use relay. *7 The lt. green key sense wire at the steering column must see a ground during remote start to keep the "SERVICE
Username: Tjmutlow
Post Number: 2208
sounds like the amp is going into protect mode, Is it new? how are the subs wired, what are the voice coils config on subs. ground amp to chasis of car, shortedt wire possible...
1991-93 Saturn SC Stereo Information
Ground Black
Illumination Gray
Dimmer Brown
Antenna Right Front
Left Front (+) Tan
Left Front (-) Gray
Left Rear (+) Brown
Username: Xplorer98
Can someone give us the wiring colors on a 1998 Ford Explorer with the Mach audio system?
Username: Tjmutlow
Post Number: 2237
if the factory wires are there, buy the aftermarket harness. the site provides no diagram for a mach system. But the wires s/b same at the amp.
1998 Ford Explorer Stereo Information
Constant 12V+ Light Green
Ground Black
Dimmer n/a
Antenna Right Front
Right Front (+) Dark Green/Orange
Right Front (-) White/Light Green
