What are the best 6x9's out there?
Username: Runit3
Portland, OR USA
Post Number: 36
I am looking for a new pair (maybe 2 pairs) of new 6x9's. I am not looking for a ton of bass (I already have an 18" in the trunk). I need some good quality higher tones, the bostons that came with my car aren't loud enough to match up with the 18"s bass so listening to lyrics doesn't really happen when the sub is hitting. If anyone has some suggestions they would b appreciated. (as a side note the bostons that i have now are rated @ 55w RMS, i'm not looking for a new amp to power new 6x9's, i just want to run them off the stock power).
Username: Adddisorder
West palm, Florida
Post Number: 467
you need an amp for them if you think there going to keep up with a sub
Username: Alteraudiousa
Concord
Post Number: 1086
try the CDT CL-69 component sets. If you're interested just email me or find me on here and i'll set you up with some. They'll handle a good amt of power and since they're components they have flexibility in install.
