Wiring
Username: Thriller73
I have 0/1 guage wiring in my car from a previous amp. The amps I am intersets in go no bigger that 2 guage. Do I have to replace all the wiring?
Username: Dustin3
Tigard, OR U.S.
Post Number: 2499
0 guage?? or 1 awg??
Username: Dustin3
Tigard, OR U.S.
Post Number: 2503
u can use it for the other amps
, it wont necessarely hurt
Username: Stnorris
Eldridge, IA US
Post Number: 666
if the amps can take 1 guage, they will be fine. the bigger the better.....
quote: it wont necessarely hurt
bassman..what are u talking about LOL.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2478
i think he means the hole isn't large enough for anything over 2 gague. thats pretty common. you'll have to either get a reducer or distribution block and run smaller out the block to the amp.
Username: Stnorris
Eldridge, IA US
Post Number: 671
lol well than that is a dumb question...if he means that the other amps can only fit 2 gauge wire, and smaller, then whats the question?
if they can only fit 2 gauge, and smaller, there not going to fit 1 gauge......lol
Username: Stnorris
Eldridge, IA US
Post Number: 672
Username: Stnorris
Eldridge, IA US
Post Number: 673
u could get new wiring, or i guess you could do a distrubtion block.....if u have money, i would get new wiring. then u will have 2 gauge, and the 1 gauge if you need it later for something......
Username: Dustin3
Tigard, OR U.S.
Post Number: 2508
why would it hurt anything to use a lil bigger wire???
Username: Stnorris
Eldridge, IA US
Post Number: 722
u said it wont necessarily hurt. you should have put it will work good if u use the bigger wire. lol. u were gunna confuse him. haha.
JP
Username: Dustin3
Tigard, OR U.S.
Post Number: 2561
stfu b!tch
Username: Dustin3
Tigard, OR U.S.
Post Number: 2562
