Help a sucker out.
Username: Maekone
Hey I just bought 2 12" Gt4-12 JBL subs, I was just wondering if any one knew of a good 2 channel, 1000w amp to power them and if that would be my best option.
heres the specifications for one of the subs.
RMS - 250w
Peak - 1000w
Frequency Response - 28Hz-450Hz
Sensitivity - 93dB
Impedance - 4 Ohms
Cheers Maek
Username: Ctmike
Ct.
Post Number: 976
a 1000w amp would probably blow those subs. look at the rms, not the peak. try and find a good mono amp that puts out 500-600w. what's your budget for an amp?
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1214
JL 500/1 PG 600.1 or alpine mrd 605
Username: Dustin3
Tigard, Or U.S.
Post Number: 2215
juliob, what about the HIFONICS BXi606? ha
kicker kx600.1
Username: Juliob
Post Number: 1225
not that hifo jeje, cuz it should be putting like 400w jeje.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2227
haha. i was thinkin around 500. haha
Username: Maekone
200-300 dollers. Would a mono amp run both subs?
Username: Dustin3
Tigard, Or U.S.
Post Number: 2251
of course they will.
you need an amp that does 500-600 @ 1 or 4 ohms. it doesnt matter if mono block or 2-channel.
kicker kx600.1 is a great amp ---- as so the pheonix gold xenon 600.1
Username: Johnfiac
Il USA
Post Number: 263
i would look for a mono amp that does about 800rms or so at 2 ohms and wire the subs like that and connect the subs for the 2ohm load instead of 4...
Username: Juliob
Post Number: 1259
first thing, those JBL are 4 SVC, if they are try getting a 2 ohm stable amp such as alpine mrd605, PG xenon 600.1, JL 500/1. If they're dual 4 ohm, try getting an amp 1 or 4 ohm stable, Directed d1200, check orion 600d, PG xenon 600.1 (again jeje with jl 500/1.)
Username: Maekone
What about this, would it get the job done well?
Specifications:
Power / channel @ 4ohm 14.4V: 400WRMS x 1
Power / channel @ 2ohm 14.4V: 700WRMS x 1
Power / channel @ 1ohm 14.4V: 820WRMS x 1
Signal/Noise ratio: >90dB
Input sensitivity: 200mV - 6V
Low pass filter: 35 - 300Hz @ 12dB/octave
Bass boost: 0 - 18dB @ 30 - 120Hz
Subsonic filter: 10 - 60Hz
Remote level controller: Yes
Dimensions: 324(L) x 258(W) x 50mm(D)
https://secure4.vivid-design.com.au/jaycar2005/productView.asp?ID=AA0428&CATID=& keywords=car+amp&SPECIAL=&form=KEYWORD&ProdCodeOnly=&Keyword1=&Keyword2=&pageNum ber=&priceMin=&priceMax=&SUBCATID=
Cheers Guys.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2332
yes. that would work. wut amp it that?
Username: Maekone
AA-0428 from jaycar. this is the link
