KickerL7 dvc
Username: Kdawg
i have a kicker L7 dual 2ohm dvc sub, what kind of amp do i need, like how many channels, how many ohms, and what ways better to hook it up parallel,series,or independent
Username: Stnorris
Eldridge, IA US
Post Number: 530
1 channel amp. that does around 800rms or more, at 1 ohm. then hook it up using a wiring diagram.
u have a 12 right?
Username: Kdawg
yeah its a 12x12" kicker
Username: Kdawg
Post Number: 7
so if i got a 1 channel amp at 1 ohm id have to hook it up in parallel?
Username: Kdawg
Post Number: 8
but wouldnt runnin my sub at 1 ohm damage it
Username: Stnorris
Eldridge, IA US
Post Number: 533
no. that doesnt affect a sub. its the amp that will be running at 1 ohm. a dual 2 ohm subwoofer can only run at 1 ohm or 4 ohm. thats its wiring choices.
to wire it, you would just hook negative on sub to negative on sub, then one of the negatives from the sub to amp. then the same for the positive.
Username: Emdawg12345
Post Number: 54
this should help http://www.rotteneggs.com/?refid=182315
