Amp for 2 M3's
Username: Crayola0
Wisconsin
Post Number: 72
I was thinking about gettin 2 15" Memphis M3's and i was wodering what amp u would recomend to power these?
Username: Crayola0
Wisconsin
Post Number: 73
I want it to be under $300 without using ebay if possible.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1241
i'm lazy, do you have sub specs and voice config?
Username: Troy81
Tavernier, Fl Us
Post Number: 532
memphis 1100d, pure perfection
Username: Juliob
Post Number: 1261
well in that case, look PG xenon 1200.1, hifonics 1206d, RE12.1, or an amp that produces 1000-1300w rms
Username: Halter
Paulding, Ohio
Post Number: 119
mepmhis 1100D is alittle pricy !!
tbh I am got a memphis mojo and the amp I am gettin is the Fusion 2000D the new powerplant line...
Username: Juliob
Post Number: 1266
first of all, those subs are 600w rms (pair) according to woofersetc. If you have the dual 4 ohm version, try using audiobahn a8002t, if you have the 4 ohm SVC use a8000t.
Username: Juliob
Post Number: 1267
if you have a memphis mojo, the dual 2 ohm version, check hifonics 1206d, for the budget.
