Help.arsenals not working
Username: Gangstafert
Jacksonville, Florida USA
Post Number: 255
Today i took out a system in a friends car to hook mine up because i dont currently have a car and im tired of looking at my stuff just sitting on the floor. Well i hooked my new amp(autotek mm1400.1)up and then proceeded to wire the two arsenal 12's to a 1ohm load after all of that i hooked it up and the only sound i got out of the subs was if i put my ear to them i could hear a scratchy sound. The amo was on and appeared to be working fine but i messed with it for atleast an hour and couldnt get no bass. Did i maybe hook something up wrong please help...
Post Number: 256
anyone????
Username: B101
Queen City, NC USA
Post Number: 3467
check ur ground wires, make SURE their SOLID! then check all power wires AGAIN.. and REMOTE wire..
what is the final ohm load from the subs goin to the amp?
Post Number: 258
I had it wired to a 1ohm load and the amp would turn on but the subs would not play all i heard was a very very light staticy sound.
Username: B101
Queen City, NC USA
Post Number: 3469
check ur rcas... something is wrong with the install... like i said check the ground!! Ive seen amps come on b4 and not play because of bad grounds.
Post Number: 259
Which rca jacks do i use on the amp ther is two.
Username: Theweasel
Steamboat springs, Colorado U.S. of A
Post Number: 526
did you try reversing polarity?
Post Number: 261
Not sure what that means or how to do it????
Username: Sgtibitoski
Clarkston, MI USA
Post Number: 51
means to reverse the wires
Post Number: 263
reverse the speaker wires? by reverse what do you mean???
Username: Aman2005
Post Number: 218
change -ve to +ve and +ve tp -ve, I think
