Plywood??
Username: Lilnomad
Marathon, Florida U.S.A.
Post Number: 100
is plywood ok for a temp box in my suburban,,i need bass for now when im drivin wit my mom(still got my permit)and i allready have plywood so i just want to throw sumthin together real quick
Username: Illuminator
Post Number: 3302
It's probably going to rattle like no other but hey, it's your box...you might be able to get it to work.
I'd rather just do it right the first time.
Username: Hdubb
Farmington, Nm Usa
Post Number: 2045
well it will work but just make sure not to get it wet. no sure how it will sound. how thick is the wood? you know for like 30 bucks you can build one out of mdf.but it will work if built correctly.
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 460
hasnt the mdf gone up in price? what would a sheet cost?
Username: Quig
Pittsburgh, Pa Us
Post Number: 219
i got my sheet for liek 22$ 8'x4'... built one 15" and still have more then half sheet left.
Username: James1115
Ct
Post Number: 6035
plywood boxes are fine, the only bad thing about them is the void's in plywood. They can flex and even blow out leaving you with a box with holes in it. If you want to build a box out of plywood I would reccomend marine greade(void free) but it is much more expensive then MDF. A sheet of MDF is about $25 then some glue and screw's and your golden.
Username: Lilnomad
Post Number: 102
ok,,can u get mdf at home depot
Username: James1115
Ct
Post Number: 6037
yup
Username: Lilnomad
Post Number: 103
ok
Username: Hdubb
Farmington, Nm Usa
Post Number: 2053
and they will even cut the wood for you. make sure you plan out your box and use interior measurements. what up james?
Username: Thomas_g
NM
Post Number: 1346
I get my mdf at home depot for $26 per sheet 8'X4'
Post Number: 463
arond same price in canada? or are you guys in canada too?
Username: James1115
Ct
Post Number: 6047
what up KIIIDDDDD! how's life in NM? knockin bitty's up left and right lol?
Username: Redliner
Wilmington, Ma
Post Number: 2117
alot of people use plywood but the stuff james is tlaking about that is void free cause it is lighter tha mdf so it doesnt weight ther cars down as much and it sounds just the same and actually the way people were tlaking about it on another site plywood doesnt flex as much as mdf and it doesnt create as much saw dust when cutting
Username: Thomas_g
NM
Post Number: 1349
wat up? You eva been to NM James??? Tha land of enchantment is fu*kin tight. Where u from conneticut, damn u live way in tha fu*k on tha east coast. O sh!t Hunter u from NM too!!! Tight your the first i see on this site from here.
Username: Rovin
Trinidad & T...
Post Number: 8383
i used 2 build boxes of good grade plywood yrs ago b4 mdf was as common as now - ply used 2 work fine but seeing now that mdf is just as available & its a better box building material thats actually cheaper too - hands down go with mdf ......
Username: Frkkevin
Denton, Texas US
Post Number: 196
Glad I get that stuff for free : )
