Box Building Holes
Username: Blazerboy
Post Number: 49
Hey guys,
well I got another question for you guys, Well since i pulled a noob move and ordered from IndoAudio my subs still are not here but I still want to make the box this weekend. I think I have all the specsready, can can go get wood anytime now but since I dont have the subs how big should I make the whole? BTW They are 12" RF punch stage 1n's. Thanks for your help.
Username: Rovin
Trinidad & T...
Post Number: 8405
according 2 RF site they rec 4 a ported box 1.25cuft & 32hz freq
since its such a small vol i doubt u can fit bigger than a 2.5" pvc pipe cause if u try a 3" pipe it will end up being long & wont fit in ur box easily ....
http://www.the12volt.com/caraudio/boxcalcs.asp
try it ^^^^& u will see what i mean ....
Username: Blazerboy
Post Number: 50
Yea, im actually thinking about keeping it enclosed actually, the holes i was refering to are the ones that the subs go in, again they are 12" subs so should I cut like 11 or 11.5 " holes for them?
Username: Killer44
Ontario Canada
Post Number: 563
i think he means the whole to put the sub in rovin...just go to
http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/std_adp.php? p_faqid=272
and download the manual and it will tell you the whole cut out for the subs....hope thats what you were asking...
Username: Blazerboy
Post Number: 51
Yea thank you both, Problem solved.
