New subs
Username: Davidalexander
Graham, Texas Us
Post Number: 31
im wanting to replace my 15 rfp3 i was thinking a eclipse ti or re sx i want it to get loud. i have 1200 watts rms at 1 ohm
Username: Freezeman_7
Post Number: 110
i think you should go with the re... but i think the re sx is a four ohm sub.. whats your amp rated at four ohms if its jus 1200wrms at 1 ohm your prolly gonna need a new amp the sx is 1000wrms at 4 ohms.. i think not positive tho
Graham, Texas Us
Post Number: 32
does anyone know what the going price is on an sx?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7956
all sx are dvc 2ohm...unless they are custom
and check on ebay...for the lowest prices..since u can no longer buy direct from re...
Username: Cenus
420 , 420 420
Post Number: 1981
you might also wanna look at the AA havoc, RE mx, SI mag, those subs are better than the sx but there probally gonna cost more.
Username: Dustin3
Tigard, Or U.S.
Post Number: 2088
wuts the website for the mag?
Username: Cenus
420 , 420 420
Post Number: 1982
http://www.stereointegrity.com/
Graham, Texas Us
Post Number: 35
well i didnt want to spend $500 on a sub really i was looking for something close to $300 with a high spl output
thanks for the help
